eserafinojr
- Apr 26, 2016
Thanks for getting back to me.
I just pulled the trigger, I have the MK-6+ with the fan upgrade coming with a new balanced dac, and the HE-560's with a balanced cable. Also have a set of 4 Svetlana Winged C 6AS7G, and a set of two Tung- Sol 6SN7GTB. Hoping I will enjoy these, and maybe they will be an upgrade over the stock tubes.
Awesome!
You made a GREAT choice, it sounds better, has less noise and way more drive than much more expensive OTL offerings like the WA22... I owned one!
NOS Winged C's sound very good. IMO though Soviet tubes made after 1984/5 started to fall off in quality, anything NOS before you're good.
The Svetlana's are the creame of the crop for the 6AS7G type, my go to tube type for the 6AS7/6080 type is the WE421A or TS 7236.
I currently use 4x Early 50s Pale Grey Plate WE 421s with the "5998/421A" label, which are my favorite 421As variants. Late 60s TS 5998 Black Plates are also very nice.
And rotate 6N7Gs, and the 6J5GT/6C5GT as drivers.
Your tube compliment will sound very very good with TS 6SN7s. Are they NOS or Russian Re-Makes?
The New Sensor Corp Re-Makes are getting pretty good I hear, you're good either way!
Tube rolling can get very pricey. I have been collecting for awhile, good NOS tubes can get crazy expensive.
BTW even though LD calls for the high gain cousin of the 6SN7, the 6SL7 to be used in the MK6, I hear no difference in gain or drive with medium gain 6SN7 type tubes or the aforementioned tubes with adapters.
