voicemaster
Hmm right now, I am having a channel imbalance on the right side =(.
archy121 said:Can you please try thse with some Trance tracks. I really want to fall in love with these like the EPH100 but hearing that 3D stereo is weakend along with sparkle is making me wonder if they sill be suitable upgrade. Probably hreat for Hip Hoip/Drum n Bass but begining to think the drop in sparkle will hurt listening to Trance.
In not a fan of very highs as i get ached easil. The EPH100 had just right highs though not the most accurate. Can these replace and possible better the EPH100 for Trance ?
Yep the left side where the control pod located is slightly louder. It is very very subtle, but it really annoys me. I played dota2 using the yamaha and the soundstage is very weird.
My ears grown tired after an hour period because of the fit: I find the nozzle of M200 is not much bend-able ,not as much as the GR07. I could say they bend for about 0.1-0.3 mm at best. The body of the earphone is too big it reminds me of earbuds. As the result, I always have difficulty fitting the earphones and it's not as easy as the EPH-100. Although the EPH-100 has bigger nozzle it's easier to insert because it has bullet-shape housing; yet, it's smaller and can be worn over-the ears. The M200, on the other hand, my goodness. I find the controller, which is bigger than the EPH-100, bothers a lot whenever I walk and work out and the design prevents from wearing over-the-ear. Yet, the M200 nozzle only fits to its stock eartips and no 'aftermarket' or different brands of eartips I've tried won't fit these, not even the Sony Hybrids.
Yet, the forwaded mid is fatiguing as well as I find that I'm sensitive to mid. Combined with the uncomfortable fit, I decided that I had to return these. Treble-sensitive, bass seeking, and non-senstive mid listeners may like these but this earphone is not for me because it sounds so intimate that every favorite tracks I threw sound so congested and confusing.
For me, the fit is great. I have a pretty standard ear meaning 99% of IEMs that I have tried, I never had any fit issue. It is funny that you said the sony hybrid tip won't fit because I tried it and it fit just fine. I also tried comply t-400 and it won't fit because the comply is too big. Again, I won't recommend the m200 tho, you can get a much better sound for half the price. IEMs like Zero Audio, Ostry, RockJaw, havi, ttpod and many more are much better option in term of price and performance imho.
* moved to Duoza thread.
Was going to respond to suggest the DuoZA, anyway since a more spacious stage is ideal for Trance...mine are on order, I'll try your test tracks when they arrive.
Douza were on my list but then I realised that the EPH100s were on sale and I couldn't resist.
So nice to see these babies again! I'm holding back from listening to them, as I just want to saviour the moment and find the right time to plug them in.
You must really like the EPH100s since you're buying them a 2nd time, lol. They were on my radar for a while but ended up getting the Pro 500, M200, etc. Hopefully the DuoZA will be a true upgrade to the EPH100s...I keep telling myself that even with their large stage they won't have that solid, hard-hitting bass punch that I crave in minimal, dubstep, dnb, etc. I'm hoping the DuoZA will have similar sound stage/extension but with deeper bass, slightly more forward mids- that'd make me really happy for an all-around EDM phone that can make Trance sound ethreal...otherwise I'll have to entertain myself with the idea of "trying" them before they're gone for good...man, this hobby is brutal.>_<
EPH-100 is the best IEM I could think of, with confident lol. It's hard to find other earphones that sounds similar, I think Carbo basso comes in mind ( deep bass and big soundstage) but the treble isn't close to it as it's somewhat grainy when played loudly. I hope DuoZa could rival the EPH-100; darn EPH-100 needs a successor to keep up with them rivals!!
+1
Hoping Duoza can better it else another eph100 coming just for my edm/trance needs.
