ilmothedude
- Dec 20, 2014
I only use artist playlist navigation mode on my 780, and there you can play all the albums in order that are under same artist. Select the artist playlist, then artist you want to listen and first opition is "play all album". If you select song inside the album directly, it will play that album in order to the end and then returns to first track of album and then pauses (if you have repeat off).Hello to all Xuelin 780 user's,
think, i found it in the playlist option's.. never thought to find it there.. but some other tip's and how 2 are welcome.
(i like my 780 really, but maybe someone could give me a little help.
how can i play all folders from one artist.
i tried it this way:
explorer-> sd card -> then scroll to the main folder of the artist -> press enter -> but then i can only confirm the different album's within the main folder -> then press ok again and i'm in alnum folder wih the tracks.
if i then press ok, just the selectet song will be played.
repeat is off and shuffle is on.
i'm shure , it's my fault, but sometimes i want to play all songs from one artist or at least just a whole album from one artist, ( i have a main folder for everey artist and the diff. albums in there)
would be nice, someone could enlighten my mind, because it's probably so easy, but i couldn't see it)
If you don't see playlist options for sd card content (artist, albums, genres etc) then you have older firmware.
