when I put my hand on the top back area (the dac underneath) of the xduoo XD-05 pro after a longer while listening it is very toasty warm. Have to pay attention to the front part (opamp section). when using heat paste it would be better having in form of strips which makes it also easier und less messy for removing.Like the others have said, most of the heat comes from the amp section not the DAC.
That looks messed up btw.
XDUoo XD05PRO
- Thread starter jockwong
You’re right. I checked this and the top section at the back gets quite warm. But the hottest seems to be the middle section ?when I put my hand on the top back area (the dac underneath) of the xduoo XD-05 pro after a longer while listening it is very toasty warm. Have to pay attention to the front part (opamp section). when using heat paste it would be better having in form of strips which makes it also easier und less messy for removing.
Arctic Cooling Thermal Strips 2 x Pack of 6-W/mK 120 x 20 x 1 mm
MikeGut
I've been trying to find the right dc to usb c converter. I got a couple from Amazon initially, but I found out later that they did not work with a 12 v source. I have the iFi iPower X 12V. Any suggestions? Mike Gutierrez, North Hollywood, California.
VisalEziomi
Does XD05 pro is easy access to replace battery?
Ben86
- Jun 24, 2015
Just found this amazing item on AliExpress. Check it out!I've been trying to find the right dc to usb c converter. I got a couple from Amazon initially, but I found out later that they did not work with a 12 v source. I have the iFi iPower X 12V. Any suggestions? Mike Gutierrez, North Hollywood, California.
€1.62 | 1PC JACK 5.5*2.1mm FEMALE TO USB C ADAPTER, USB ADAPTOR TYPE C MALE TO DC 5.5 x 2.1 mm CHARGR CONNECTOR
https://a.aliexpress.com/_EvApHJB
These will work with any 12V linear 5.5x2.5/2.1 power supply or any ifi power adapter. I use it with my 12V linear power supply and also checked with Ifi power-x 12V
MikeGut
Thanks for the info.Just found this amazing item on AliExpress. Check it out!
Congrats ! Yes it is amazing and it's one of the few feature complete audio gadgets.david vs goliath, this little dac/amp is really amazing! Perfect companion for on the go, can’t wait for the r2r module
Speaking of R2R - anyone has any update from Xduoo ?
Acidicfriend
The output impedance unbalanced is .02 ohms correct? It seems there is a typo on Apos that claims an unbalanced output impedance of 50.02 -
Djankie
- Apr 7, 2010
How does it do compared to envy?david vs goliath, this little dac/amp is really amazing! Perfect companion for on the go, can’t wait for the r2r module
Cecala
- Mar 15, 2007
What happened in the end, did you fix the issue?Hi folks,
My.display showed this to me last week, and since then the front display is gone.
The player still can produce sound, and the volume dial display still works. But now I m like using the XD05PRO like a blind man.
Anybody has encountered this before?
Is Xudoo support my only option? I got my unit from Taobao direct.
Tks for all input in advance..
@quaddac
Today is the day. My xd05pro only works in ext mode. Charge and batt modes do not work. In charge mode it behaves the same as in ext mode. Batt mode = 0. The battery was not discharged.
How do you think it is due to the disability xD05, which required continuous use of the rear switch if the power supply did not provide 12V permanently?
TBH, I’m not able to compare both, both are great, the one for home listening the other for on the go or vacation…How does it do compared to envy?
I don't think it's a switch issue, because my unit works mainly in stationary mode (with LPS). However, I cannot rule it out. I won't send it to the service center until tomorrow. Earlier I noticed that the battery also discharges in stationary mode. Not very significantly, but still. When I find out something, I will write.@quaddac
sofastreamer
- Dec 14, 2007
have to say i am impressed how helpful Nioh is in this thread. Thank you bro!
Total: 6 (members: 0, guests: 6)
