meneergolf
- Apr 8, 2017
There have been a couple of us that have had some issues with the V5i cutting off, either with using high gain, or combination of bass boost plus high gain. I sent my V5i back and got a replacement that had the same issue. In talking with the people at Burson, they identified that the issue might be with the capacitors inside the Xd-05 and the solution might be to change them to better caps as the problem is most likely irregular voltage. I might do that at some point in the future with the 4 10uF 50V caps that surround the opamp, and maybe the 2 22uF 16v caps that are by the battery.
I don't know if anyone is doing this at the moment but I'm willing to try. I know little about capacitors but if someone could tell me what to upgrade those caps with I might give it a go as I do know how to solder. If it's a bad idea please tell.
