XDuoo X3 DSD 24Bit / 192KHz CS4398 Chip Lossless Music Player
Jun 23, 2016 at 2:29 PM Post #3,481 of 5,194
okay, that makes sense, and I now see what the issue is with xVortex's rockbox...
whether blessed by Rockbox or not, I appreciate it.
I was surprized I could hear the pitch error on a few songs, if I thought I heard it I A > B 'd it against the rockboxed version
and definitely hear a difference.
Placebo effect? I don't know.
and I more than appreciate the fix for Gapless play.
Jun 23, 2016 at 2:57 PM Post #3,483 of 5,194
Vapman,
  I'm confused.  Vortex posted his source code on GitHub which I assumed was open since it's disclosed.   What's a "closed source fork"?
THX
Good point, what I really meant is that it's a fork of an older version of rockbox, and isn't in line with the official rockbox development.
So someome could do work on vortex's port, but then it'd be a fork of a fork of an outdated rockbox and that's where things can get ugly.
FYI I still don't understand the hate on the stock FW, if the pitch issue is there I can't hear it but I can tune a piano(properly)?
Ah, thanks for the clarification.  It could be, and I'm guessing, that because xDuoo choose to imbed so much of their firmware code in the meager 128mB of internal memory, Vortex had to use an older version of RB to make the port effective.
As for the pitch issue, many don't hear it at all, some with only certain songs (me for example), and others on almost everything.  Tuning a guitar or piano may not fully correlate to hearing a pitch issue in playback as one is focusing differently.  Again just speculation on my part.
The stock firmware is also flawed in a number of other ways which is why so many have distain for it (e.g. gapless play, replay-gain, crossfeed, equilization, etc. all missing).
Jun 23, 2016 at 3:35 PM Post #3,484 of 5,194
Rockbox requires about 2.5 MB of RAM.
The Vortex build was forked in March, so it is very nearly up to date.  What is not up to date is his source code link.  So while you can compile a build, it won't be the same one he is distributing, which makes it very hard for anyone else to work on the port.
Jun 23, 2016 at 3:39 PM Post #3,485 of 5,194
Thank you Sir.  It all makes sense now.
Jun 23, 2016 at 4:27 PM Post #3,486 of 5,194
I'm glad you think so Bob, it's as clear as mud for me.....
on a different note I wonder if the battery issue is caused by newer units having larger capacity battery and the Rockbox code was
developed for smaller battery... just a thought.
Jun 23, 2016 at 4:27 PM Post #3,487 of 5,194
http://pastebin.com/wvF9qtci
Guys here's my battery bench... Dang, it reachs nearly 12h on continuos playing, so the problem there is only when you start skipping songs, damn.
The only thing that I don't understand is why "Left time" shows always -1.
Jun 23, 2016 at 4:34 PM Post #3,488 of 5,194
# This plugin will log your battery performance in a
# file (//battery_bench.txt) every minute.
# To properly test your battery:
# 1) Select and playback an album. (Be sure to be more than the player's buffer)
# 2) Set to repeat.
# 3) Let the player run completely out of battery.
# 4) Recharge and copy (or whatever you want) the txt file to your computer.
# Now you can make graphs with the data of the battery log.
# Do not enter another plugin during the test or else the
# logging activity will end.
# P.S: You can decide how you will make your tests.
# Just don't open another plugin to be sure that your log will continue.
# Battery bench run for xDuoo X3 version b708dbc-160501
# Battery type: 2000 mAh      Buffer Entries: 1000
# Rockbox has been running for 00:00:35
# Time:,  Seconds:,  Level:,  Time Left:,  Voltage[mV]:, C:, S:, U:
00:00:07,  00007,     100%,     00:-1,         4181,     -,  -,  -
00:01:07,  00067,     100%,     00:-1,         4172,     -,  -,  -
00:02:07,  00127,     100%,     00:-1,         4168,     -,  -,  -
00:03:07,  00187,     100%,     00:-1,         4165,     -,  -,  -
00:04:07,  00247,     100%,     00:-1,         4163,     -,  -,  -
00:05:07,  00307,     100%,     00:-1,         4160,     -,  -,  -
00:06:07,  00367,     099%,     00:-1,         4159,     -,  -,  -
00:07:07,  00427,     099%,     00:-1,         4157,     -,  -,  -
00:08:07,  00487,     099%,     00:-1,         4155,     -,  -,  -
00:09:07,  00547,     099%,     00:-1,         4153,     -,  -,  -
00:10:07,  00607,     099%,     00:-1,         4152,     -,  -,  -
00:11:07,  00667,     098%,     00:-1,         4150,     -,  -,  -
00:12:07,  00727,     098%,     00:-1,         4148,     -,  -,  -
00:13:07,  00787,     098%,     00:-1,         4148,     -,  -,  -
00:14:07,  00847,     098%,     00:-1,         4146,     -,  -,  -
00:15:07,  00907,     098%,     00:-1,         4144,     -,  -,  -
00:16:07,  00967,     098%,     00:-1,         4142,     -,  -,  -
00:17:07,  01027,     098%,     00:-1,         4141,     -,  -,  -
00:18:07,  01087,     097%,     00:-1,         4139,     -,  -,  -
00:19:07,  01147,     097%,     00:-1,         4137,     -,  -,  -
00:20:07,  01207,     097%,     00:-1,         4137,     -,  -,  -
00:21:07,  01267,     097%,     00:-1,         4135,     -,  -,  -
00:22:07,  01327,     097%,     00:-1,         4134,     -,  -,  -
00:23:07,  01387,     097%,     00:-1,         4132,     -,  -,  -
00:24:07,  01447,     097%,     00:-1,         4131,     -,  -,  -
00:25:07,  01507,     096%,     00:-1,         4129,     -,  -,  -
00:26:07,  01567,     096%,     00:-1,         4128,     -,  -,  -
00:27:07,  01627,     096%,     00:-1,         4126,     -,  -,  -
00:28:07,  01687,     096%,     00:-1,         4125,     -,  -,  -
00:29:07,  01747,     096%,     00:-1,         4123,     -,  -,  -
00:30:07,  01807,     096%,     00:-1,         4122,     -,  -,  -
00:31:07,  01867,     095%,     00:-1,         4120,     -,  -,  -
00:32:07,  01927,     095%,     00:-1,         4119,     -,  -,  -
00:33:07,  01987,     095%,     00:-1,         4118,     -,  -,  -
00:34:07,  02047,     095%,     00:-1,         4116,     -,  -,  -
00:35:07,  02107,     095%,     00:-1,         4115,     -,  -,  -
00:36:07,  02167,     095%,     00:-1,         4113,     -,  -,  -
00:37:07,  02227,     095%,     00:-1,         4113,     -,  -,  -
00:38:07,  02287,     095%,     00:-1,         4111,     -,  -,  -
00:39:07,  02347,     094%,     00:-1,         4110,     -,  -,  -
00:40:07,  02407,     094%,     00:-1,         4108,     -,  -,  -
00:41:07,  02467,     094%,     00:-1,         4107,     -,  -,  -
00:42:07,  02527,     094%,     00:-1,         4106,     -,  -,  -
00:43:07,  02587,     094%,     00:-1,         4104,     -,  -,  -
00:44:07,  02647,     094%,     00:-1,         4104,     -,  -,  -
00:45:07,  02707,     094%,     00:-1,         4102,     -,  -,  -
00:46:07,  02767,     094%,     00:-1,         4101,     -,  -,  -
00:47:07,  02827,     093%,     00:-1,         4099,     -,  -,  -
00:48:07,  02887,     093%,     00:-1,         4098,     -,  -,  -
00:49:07,  02947,     093%,     00:-1,         4097,     -,  -,  -
00:50:07,  03007,     093%,     00:-1,         4095,     -,  -,  -
00:51:07,  03067,     093%,     00:-1,         4094,     -,  -,  -
00:52:07,  03127,     093%,     00:-1,         4092,     -,  -,  -
00:53:07,  03187,     093%,     00:-1,         4091,     -,  -,  -
00:54:07,  03247,     092%,     00:-1,         4090,     -,  -,  -
00:55:07,  03307,     092%,     00:-1,         4089,     -,  -,  -
00:56:07,  03367,     092%,     00:-1,         4087,     -,  -,  -
00:57:07,  03427,     092%,     00:-1,         4086,     -,  -,  -
00:58:07,  03487,     092%,     00:-1,         4084,     -,  -,  -
00:59:07,  03547,     092%,     00:-1,         4083,     -,  -,  -
01:00:07,  03607,     092%,     00:-1,         4082,     -,  -,  -
01:01:07,  03667,     092%,     00:-1,         4081,     -,  -,  -
01:02:07,  03727,     091%,     00:-1,         4080,     -,  -,  -
01:03:07,  03787,     091%,     00:-1,         4078,     -,  -,  -
01:04:07,  03847,     091%,     00:-1,         4077,     -,  -,  -
01:05:07,  03907,     091%,     00:-1,         4076,     -,  -,  -
01:06:07,  03967,     091%,     00:-1,         4074,     -,  -,  -
01:07:07,  04027,     091%,     00:-1,         4073,     -,  -,  -
01:08:07,  04087,     091%,     00:-1,         4072,     -,  -,  -
01:09:07,  04147,     091%,     00:-1,         4071,     -,  -,  -
01:10:07,  04207,     090%,     00:-1,         4070,     -,  -,  -
01:11:07,  04267,     090%,     00:-1,         4069,     -,  -,  -
01:12:07,  04327,     090%,     00:-1,         4067,     -,  -,  -
01:13:07,  04387,     090%,     00:-1,         4066,     -,  -,  -
01:14:07,  04447,     090%,     00:-1,         4064,     -,  -,  -
01:15:07,  04507,     090%,     00:-1,         4064,     -,  -,  -
01:16:07,  04567,     090%,     00:-1,         4062,     -,  -,  -
01:17:07,  04627,     090%,     00:-1,         4062,     -,  -,  -
01:18:07,  04687,     089%,     00:-1,         4060,     -,  -,  -
01:19:07,  04747,     089%,     00:-1,         4059,     -,  -,  -
01:20:07,  04807,     089%,     00:-1,         4057,     -,  -,  -
01:21:07,  04867,     089%,     00:-1,         4057,     -,  -,  -
01:22:07,  04927,     089%,     00:-1,         4056,     -,  -,  -
01:23:07,  04987,     089%,     00:-1,         4054,     -,  -,  -
01:24:07,  05047,     089%,     00:-1,         4053,     -,  -,  -
01:25:07,  05107,     088%,     00:-1,         4052,     -,  -,  -
01:26:07,  05167,     088%,     00:-1,         4051,     -,  -,  -
01:27:07,  05227,     088%,     00:-1,         4050,     -,  -,  -
01:28:07,  05287,     088%,     00:-1,         4049,     -,  -,  -
01:29:07,  05347,     088%,     00:-1,         4047,     -,  -,  -
01:30:07,  05407,     088%,     00:-1,         4047,     -,  -,  -
01:31:07,  05467,     088%,     00:-1,         4045,     -,  -,  -
01:32:07,  05527,     088%,     00:-1,         4044,     -,  -,  -
01:33:07,  05587,     087%,     00:-1,         4042,     -,  -,  -
01:34:07,  05647,     087%,     00:-1,         4041,     -,  -,  -
01:35:07,  05707,     087%,     00:-1,         4039,     -,  -,  -
01:36:07,  05767,     087%,     00:-1,         4039,     -,  -,  -
01:37:07,  05827,     087%,     00:-1,         4037,     -,  -,  -
01:38:07,  05887,     087%,     00:-1,         4037,     -,  -,  -
01:39:07,  05947,     087%,     00:-1,         4035,     -,  -,  -
01:40:07,  06007,     086%,     00:-1,         4034,     -,  -,  -
01:41:07,  06067,     086%,     00:-1,         4032,     -,  -,  -
01:42:07,  06127,     086%,     00:-1,         4032,     -,  -,  -
01:43:07,  06187,     086%,     00:-1,         4030,     -,  -,  -
01:44:07,  06247,     086%,     00:-1,         4029,     -,  -,  -
01:45:07,  06307,     086%,     00:-1,         4028,     -,  -,  -
01:46:07,  06367,     086%,     00:-1,         4026,     -,  -,  -
01:47:07,  06427,     085%,     00:-1,         4025,     -,  -,  -
01:48:07,  06487,     085%,     00:-1,         4024,     -,  -,  -
01:49:07,  06547,     085%,     00:-1,         4023,     -,  -,  -
01:50:07,  06607,     085%,     00:-1,         4021,     -,  -,  -
01:51:07,  06667,     085%,     00:-1,         4020,     -,  -,  -
01:52:07,  06727,     085%,     00:-1,         4019,     -,  -,  -
01:53:07,  06787,     085%,     00:-1,         4018,     -,  -,  -
01:54:07,  06847,     084%,     00:-1,         4016,     -,  -,  -
01:55:07,  06907,     084%,     00:-1,         4015,     -,  -,  -
01:56:07,  06967,     084%,     00:-1,         4014,     -,  -,  -
01:57:07,  07027,     084%,     00:-1,         4013,     -,  -,  -
01:58:07,  07087,     084%,     00:-1,         4011,     -,  -,  -
01:59:07,  07147,     084%,     00:-1,         4011,     -,  -,  -
02:00:07,  07207,     084%,     00:-1,         4009,     -,  -,  -
02:01:07,  07267,     083%,     00:-1,         4008,     -,  -,  -
02:02:07,  07327,     083%,     00:-1,         4007,     -,  -,  -
02:03:07,  07387,     083%,     00:-1,         4006,     -,  -,  -
02:04:07,  07447,     083%,     00:-1,         4005,     -,  -,  -
02:05:07,  07507,     083%,     00:-1,         4003,     -,  -,  -
02:06:07,  07567,     083%,     00:-1,         4002,     -,  -,  -
02:07:07,  07627,     083%,     00:-1,         4001,     -,  -,  -
02:08:07,  07687,     083%,     00:-1,         4000,     -,  -,  -
02:09:07,  07747,     082%,     00:-1,         3998,     -,  -,  -
02:10:07,  07807,     082%,     00:-1,         3997,     -,  -,  -
02:11:07,  07867,     082%,     00:-1,         3996,     -,  -,  -
02:12:07,  07927,     082%,     00:-1,         3995,     -,  -,  -
02:13:07,  07987,     082%,     00:-1,         3994,     -,  -,  -
02:14:07,  08047,     082%,     00:-1,         3993,     -,  -,  -
02:15:07,  08107,     082%,     00:-1,         3992,     -,  -,  -
02:16:07,  08167,     082%,     00:-1,         3991,     -,  -,  -
02:17:07,  08227,     081%,     00:-1,         3989,     -,  -,  -
02:18:07,  08287,     081%,     00:-1,         3989,     -,  -,  -
02:19:07,  08347,     081%,     00:-1,         3987,     -,  -,  -
02:20:07,  08407,     081%,     00:-1,         3986,     -,  -,  -
02:21:07,  08467,     081%,     00:-1,         3985,     -,  -,  -
02:22:07,  08527,     081%,     00:-1,         3985,     -,  -,  -
02:23:07,  08587,     081%,     00:-1,         3983,     -,  -,  -
02:24:07,  08647,     080%,     00:-1,         3981,     -,  -,  -
02:25:07,  08707,     080%,     00:-1,         3980,     -,  -,  -
02:26:07,  08767,     080%,     00:-1,         3980,     -,  -,  -
02:27:07,  08827,     080%,     00:-1,         3979,     -,  -,  -
02:28:07,  08887,     080%,     00:-1,         3978,     -,  -,  -
02:29:07,  08947,     080%,     00:-1,         3976,     -,  -,  -
02:30:07,  09007,     080%,     00:-1,         3976,     -,  -,  -
02:31:07,  09067,     080%,     00:-1,         3974,     -,  -,  -
02:32:07,  09127,     080%,     00:-1,         3973,     -,  -,  -
02:33:07,  09187,     080%,     00:-1,         3973,     -,  -,  -
02:34:07,  09247,     079%,     00:-1,         3972,     -,  -,  -
02:35:07,  09307,     079%,     00:-1,         3971,     -,  -,  -
02:36:07,  09367,     079%,     00:-1,         3970,     -,  -,  -
02:37:07,  09427,     079%,     00:-1,         3969,     -,  -,  -
02:38:07,  09487,     079%,     00:-1,         3968,     -,  -,  -
02:39:07,  09547,     079%,     00:-1,         3967,     -,  -,  -
02:40:07,  09607,     078%,     00:-1,         3966,     -,  -,  -
02:41:07,  09667,     078%,     00:-1,         3965,     -,  -,  -
02:42:07,  09727,     078%,     00:-1,         3964,     -,  -,  -
02:43:07,  09787,     078%,     00:-1,         3963,     -,  -,  -
02:44:07,  09847,     078%,     00:-1,         3962,     -,  -,  -
02:45:07,  09907,     078%,     00:-1,         3961,     -,  -,  -
02:46:07,  09967,     078%,     00:-1,         3960,     -,  -,  -
02:47:07,  10027,     078%,     00:-1,         3960,     -,  -,  -
02:48:07,  10087,     077%,     00:-1,         3958,     -,  -,  -
02:49:07,  10147,     077%,     00:-1,         3957,     -,  -,  -
02:50:07,  10207,     077%,     00:-1,         3956,     -,  -,  -
02:51:07,  10267,     077%,     00:-1,         3955,     -,  -,  -
02:52:07,  10327,     077%,     00:-1,         3954,     -,  -,  -
02:53:07,  10387,     077%,     00:-1,         3954,     -,  -,  -
02:54:07,  10447,     076%,     00:-1,         3952,     -,  -,  -
02:55:07,  10507,     076%,     00:-1,         3950,     -,  -,  -
02:56:07,  10567,     076%,     00:-1,         3950,     -,  -,  -
02:57:07,  10627,     076%,     00:-1,         3949,     -,  -,  -
02:58:07,  10687,     076%,     00:-1,         3948,     -,  -,  -
02:59:07,  10747,     076%,     00:-1,         3948,     -,  -,  -
03:00:07,  10807,     075%,     00:-1,         3946,     -,  -,  -
03:01:07,  10867,     075%,     00:-1,         3945,     -,  -,  -
03:02:07,  10927,     075%,     00:-1,         3944,     -,  -,  -
03:03:07,  10987,     075%,     00:-1,         3943,     -,  -,  -
03:04:07,  11047,     075%,     00:-1,         3942,     -,  -,  -
03:05:07,  11107,     075%,     00:-1,         3940,     -,  -,  -
03:06:07,  11167,     075%,     00:-1,         3940,     -,  -,  -
03:07:07,  11227,     074%,     00:-1,         3939,     -,  -,  -
03:08:07,  11287,     074%,     00:-1,         3938,     -,  -,  -
03:09:07,  11347,     074%,     00:-1,         3937,     -,  -,  -
03:10:07,  11407,     074%,     00:-1,         3936,     -,  -,  -
03:11:07,  11467,     074%,     00:-1,         3935,     -,  -,  -
03:12:07,  11527,     074%,     00:-1,         3934,     -,  -,  -
03:13:07,  11587,     073%,     00:-1,         3932,     -,  -,  -
03:14:07,  11647,     073%,     00:-1,         3932,     -,  -,  -
03:15:07,  11707,     073%,     00:-1,         3931,     -,  -,  -
03:16:07,  11767,     073%,     00:-1,         3930,     -,  -,  -
03:17:07,  11827,     073%,     00:-1,         3929,     -,  -,  -
03:18:07,  11887,     073%,     00:-1,         3928,     -,  -,  -
03:19:07,  11947,     073%,     00:-1,         3927,     -,  -,  -
03:20:07,  12007,     072%,     00:-1,         3926,     -,  -,  -
03:21:07,  12067,     072%,     00:-1,         3925,     -,  -,  -
03:22:07,  12127,     072%,     00:-1,         3924,     -,  -,  -
03:23:07,  12187,     072%,     00:-1,         3923,     -,  -,  -
03:24:07,  12247,     072%,     00:-1,         3922,     -,  -,  -
03:25:07,  12307,     072%,     00:-1,         3921,     -,  -,  -
03:26:07,  12367,     072%,     00:-1,         3921,     -,  -,  -
03:27:07,  12427,     071%,     00:-1,         3919,     -,  -,  -
03:28:07,  12487,     071%,     00:-1,         3919,     -,  -,  -
03:29:07,  12547,     071%,     00:-1,         3917,     -,  -,  -
03:30:07,  12607,     071%,     00:-1,         3917,     -,  -,  -
03:31:07,  12667,     071%,     00:-1,         3916,     -,  -,  -
03:32:07,  12727,     071%,     00:-1,         3915,     -,  -,  -
03:33:07,  12787,     071%,     00:-1,         3914,     -,  -,  -
03:34:07,  12847,     071%,     00:-1,         3913,     -,  -,  -
03:35:07,  12907,     070%,     00:-1,         3912,     -,  -,  -
03:36:07,  12967,     070%,     00:-1,         3911,     -,  -,  -
03:37:07,  13027,     070%,     00:-1,         3910,     -,  -,  -
03:38:07,  13087,     070%,     00:-1,         3909,     -,  -,  -
03:39:07,  13147,     070%,     00:-1,         3908,     -,  -,  -
03:40:07,  13207,     070%,     00:-1,         3907,     -,  -,  -
03:41:07,  13267,     070%,     00:-1,         3906,     -,  -,  -
03:42:07,  13327,     069%,     00:-1,         3905,     -,  -,  -
03:43:07,  13387,     069%,     00:-1,         3905,     -,  -,  -
03:44:07,  13447,     069%,     00:-1,         3904,     -,  -,  -
03:45:07,  13507,     069%,     00:-1,         3902,     -,  -,  -
03:46:07,  13567,     069%,     00:-1,         3902,     -,  -,  -
03:47:07,  13627,     069%,     00:-1,         3900,     -,  -,  -
03:48:07,  13687,     069%,     00:-1,         3900,     -,  -,  -
03:49:07,  13747,     069%,     00:-1,         3899,     -,  -,  -
03:50:07,  13807,     068%,     00:-1,         3898,     -,  -,  -
03:51:07,  13867,     068%,     00:-1,         3897,     -,  -,  -
03:52:07,  13927,     068%,     00:-1,         3897,     -,  -,  -
03:53:07,  13987,     068%,     00:-1,         3895,     -,  -,  -
03:54:07,  14047,     068%,     00:-1,         3894,     -,  -,  -
03:55:07,  14107,     068%,     00:-1,         3893,     -,  -,  -
03:56:07,  14167,     068%,     00:-1,         3892,     -,  -,  -
03:57:07,  14227,     067%,     00:-1,         3891,     -,  -,  -
03:58:07,  14287,     067%,     00:-1,         3890,     -,  -,  -
03:59:07,  14347,     067%,     00:-1,         3890,     -,  -,  -
04:00:07,  14407,     067%,     00:-1,         3889,     -,  -,  -
04:01:07,  14467,     067%,     00:-1,         3888,     -,  -,  -
04:02:07,  14527,     067%,     00:-1,         3887,     -,  -,  -
04:03:07,  14587,     067%,     00:-1,         3886,     -,  -,  -
04:04:07,  14647,     066%,     00:-1,         3884,     -,  -,  -
04:05:07,  14707,     066%,     00:-1,         3884,     -,  -,  -
04:06:07,  14767,     066%,     00:-1,         3883,     -,  -,  -
04:07:07,  14827,     066%,     00:-1,         3882,     -,  -,  -
04:08:07,  14887,     066%,     00:-1,         3882,     -,  -,  -
04:09:07,  14947,     066%,     00:-1,         3880,     -,  -,  -
04:10:07,  15007,     066%,     00:-1,         3879,     -,  -,  -
04:11:07,  15067,     066%,     00:-1,         3878,     -,  -,  -
04:12:07,  15127,     065%,     00:-1,         3877,     -,  -,  -
04:13:07,  15187,     065%,     00:-1,         3876,     -,  -,  -
04:14:07,  15247,     065%,     00:-1,         3876,     -,  -,  -
04:15:07,  15307,     065%,     00:-1,         3874,     -,  -,  -
04:16:07,  15367,     065%,     00:-1,         3874,     -,  -,  -
04:17:07,  15427,     065%,     00:-1,         3873,     -,  -,  -
04:18:07,  15487,     065%,     00:-1,         3872,     -,  -,  -
04:19:07,  15547,     065%,     00:-1,         3871,     -,  -,  -
04:20:07,  15607,     064%,     00:-1,         3870,     -,  -,  -
04:21:07,  15667,     064%,     00:-1,         3869,     -,  -,  -
04:22:07,  15727,     064%,     00:-1,         3868,     -,  -,  -
04:23:07,  15787,     064%,     00:-1,         3867,     -,  -,  -
04:24:07,  15847,     064%,     00:-1,         3867,     -,  -,  -
04:25:07,  15907,     064%,     00:-1,         3865,     -,  -,  -
04:26:07,  15967,     064%,     00:-1,         3864,     -,  -,  -
04:27:07,  16027,     064%,     00:-1,         3864,     -,  -,  -
04:28:07,  16087,     063%,     00:-1,         3863,     -,  -,  -
04:29:07,  16147,     063%,     00:-1,         3861,     -,  -,  -
04:30:07,  16207,     063%,     00:-1,         3861,     -,  -,  -
04:31:07,  16267,     063%,     00:-1,         3860,     -,  -,  -
04:32:07,  16327,     063%,     00:-1,         3859,     -,  -,  -
04:33:07,  16387,     063%,     00:-1,         3859,     -,  -,  -
04:34:07,  16447,     063%,     00:-1,         3858,     -,  -,  -
04:35:07,  16507,     062%,     00:-1,         3856,     -,  -,  -
04:36:07,  16567,     062%,     00:-1,         3856,     -,  -,  -
04:37:07,  16627,     062%,     00:-1,         3854,     -,  -,  -
04:38:07,  16687,     062%,     00:-1,         3854,     -,  -,  -
04:39:07,  16747,     062%,     00:-1,         3853,     -,  -,  -
04:40:07,  16807,     062%,     00:-1,         3852,     -,  -,  -
04:41:07,  16867,     062%,     00:-1,         3851,     -,  -,  -
04:42:07,  16927,     062%,     00:-1,         3850,     -,  -,  -
04:43:07,  16987,     061%,     00:-1,         3849,     -,  -,  -
04:44:07,  17047,     061%,     00:-1,         3849,     -,  -,  -
04:45:07,  17107,     061%,     00:-1,         3848,     -,  -,  -
04:46:07,  17167,     061%,     00:-1,         3847,     -,  -,  -
04:47:07,  17227,     061%,     00:-1,         3846,     -,  -,  -
04:48:07,  17287,     061%,     00:-1,         3845,     -,  -,  -
04:49:07,  17347,     061%,     00:-1,         3844,     -,  -,  -
04:50:07,  17407,     060%,     00:-1,         3842,     -,  -,  -
04:51:07,  17467,     060%,     00:-1,         3842,     -,  -,  -
04:52:07,  17527,     060%,     00:-1,         3841,     -,  -,  -
04:53:07,  17587,     060%,     00:-1,         3840,     -,  -,  -
04:54:07,  17647,     060%,     00:-1,         3839,     -,  -,  -
04:55:07,  17707,     060%,     00:-1,         3838,     -,  -,  -
04:56:07,  17767,     060%,     00:-1,         3838,     -,  -,  -
04:57:07,  17827,     060%,     00:-1,         3837,     -,  -,  -
04:58:07,  17887,     060%,     00:-1,         3836,     -,  -,  -
04:59:07,  17947,     059%,     00:-1,         3835,     -,  -,  -
05:00:07,  18007,     059%,     00:-1,         3835,     -,  -,  -
05:01:07,  18067,     059%,     00:-1,         3833,     -,  -,  -
05:02:07,  18127,     059%,     00:-1,         3833,     -,  -,  -
05:03:07,  18187,     059%,     00:-1,         3831,     -,  -,  -
05:04:07,  18247,     058%,     00:-1,         3830,     -,  -,  -
05:05:07,  18307,     058%,     00:-1,         3829,     -,  -,  -
05:06:07,  18367,     058%,     00:-1,         3829,     -,  -,  -
05:07:07,  18427,     058%,     00:-1,         3828,     -,  -,  -
05:08:07,  18487,     058%,     00:-1,         3827,     -,  -,  -
05:09:07,  18547,     058%,     00:-1,         3826,     -,  -,  -
05:10:07,  18607,     058%,     00:-1,         3826,     -,  -,  -
05:11:07,  18667,     057%,     00:-1,         3825,     -,  -,  -
05:12:07,  18727,     057%,     00:-1,         3824,     -,  -,  -
05:13:07,  18787,     057%,     00:-1,         3823,     -,  -,  -
05:14:07,  18847,     057%,     00:-1,         3823,     -,  -,  -
05:15:07,  18907,     057%,     00:-1,         3822,     -,  -,  -
05:16:07,  18967,     057%,     00:-1,         3821,     -,  -,  -
05:17:07,  19027,     057%,     00:-1,         3821,     -,  -,  -
05:18:07,  19087,     056%,     00:-1,         3820,     -,  -,  -
05:19:07,  19147,     056%,     00:-1,         3819,     -,  -,  -
05:20:07,  19207,     056%,     00:-1,         3817,     -,  -,  -
05:21:07,  19267,     056%,     00:-1,         3817,     -,  -,  -
05:22:07,  19327,     056%,     00:-1,         3817,     -,  -,  -
05:23:07,  19387,     055%,     00:-1,         3815,     -,  -,  -
05:24:07,  19447,     055%,     00:-1,         3815,     -,  -,  -
05:25:07,  19507,     055%,     00:-1,         3814,     -,  -,  -
05:26:07,  19567,     055%,     00:-1,         3814,     -,  -,  -
05:27:07,  19627,     055%,     00:-1,         3813,     -,  -,  -
05:28:07,  19687,     055%,     00:-1,         3812,     -,  -,  -
05:29:07,  19747,     055%,     00:-1,         3812,     -,  -,  -
05:30:07,  19807,     055%,     00:-1,         3811,     -,  -,  -
05:31:07,  19867,     054%,     00:-1,         3810,     -,  -,  -
05:32:07,  19927,     054%,     00:-1,         3810,     -,  -,  -
05:33:07,  19987,     054%,     00:-1,         3809,     -,  -,  -
05:34:07,  20047,     054%,     00:-1,         3808,     -,  -,  -
05:35:07,  20107,     054%,     00:-1,         3806,     -,  -,  -
05:36:07,  20167,     054%,     00:-1,         3806,     -,  -,  -
05:37:07,  20227,     053%,     00:-1,         3805,     -,  -,  -
05:38:07,  20287,     054%,     00:-1,         3806,     -,  -,  -
05:39:07,  20347,     053%,     00:-1,         3804,     -,  -,  -
05:40:07,  20407,     053%,     00:-1,         3804,     -,  -,  -
05:41:07,  20467,     053%,     00:-1,         3803,     -,  -,  -
05:42:07,  20527,     053%,     00:-1,         3802,     -,  -,  -
05:43:07,  20587,     053%,     00:-1,         3801,     -,  -,  -
05:44:07,  20647,     053%,     00:-1,         3801,     -,  -,  -
05:45:07,  20707,     052%,     00:-1,         3800,     -,  -,  -
05:46:07,  20767,     052%,     00:-1,         3800,     -,  -,  -
05:47:07,  20827,     052%,     00:-1,         3799,     -,  -,  -
05:48:07,  20887,     052%,     00:-1,         3799,     -,  -,  -
05:49:07,  20947,     052%,     00:-1,         3798,     -,  -,  -
05:50:07,  21007,     052%,     00:-1,         3798,     -,  -,  -
05:51:07,  21067,     052%,     00:-1,         3796,     -,  -,  -
05:52:07,  21127,     052%,     00:-1,         3796,     -,  -,  -
05:53:07,  21187,     051%,     00:-1,         3795,     -,  -,  -
05:54:07,  21247,     051%,     00:-1,         3795,     -,  -,  -
05:55:07,  21307,     051%,     00:-1,         3793,     -,  -,  -
05:56:07,  21367,     051%,     00:-1,         3793,     -,  -,  -
05:57:07,  21427,     051%,     00:-1,         3792,     -,  -,  -
05:58:07,  21487,     051%,     00:-1,         3792,     -,  -,  -
05:59:07,  21547,     051%,     00:-1,         3791,     -,  -,  -
05:59:19,  21559,     050%,     00:-1,         3790,     -,  -,  -
06:00:19,  21619,     051%,     00:-1,         3791,     -,  -,  -
06:01:19,  21679,     050%,     00:-1,         3789,     -,  -,  -
06:02:19,  21739,     050%,     00:-1,         3789,     -,  -,  -
06:03:19,  21799,     050%,     00:-1,         3789,     -,  -,  -
06:04:19,  21859,     050%,     00:-1,         3787,     -,  -,  -
06:05:19,  21919,     050%,     00:-1,         3788,     -,  -,  -
06:06:19,  21979,     050%,     00:-1,         3787,     -,  -,  -
06:07:19,  22039,     050%,     00:-1,         3787,     -,  -,  -
06:08:19,  22099,     050%,     00:-1,         3786,     -,  -,  -
06:09:19,  22159,     050%,     00:-1,         3786,     -,  -,  -
06:10:19,  22219,     049%,     00:-1,         3785,     -,  -,  -
06:11:19,  22279,     049%,     00:-1,         3785,     -,  -,  -
06:12:19,  22339,     049%,     00:-1,         3784,     -,  -,  -
06:13:19,  22399,     049%,     00:-1,         3783,     -,  -,  -
06:14:19,  22459,     048%,     00:-1,         3782,     -,  -,  -
06:15:19,  22519,     048%,     00:-1,         3782,     -,  -,  -
06:16:19,  22579,     048%,     00:-1,         3781,     -,  -,  -
06:17:19,  22639,     048%,     00:-1,         3782,     -,  -,  -
06:18:19,  22699,     048%,     00:-1,         3780,     -,  -,  -
06:19:19,  22759,     048%,     00:-1,         3780,     -,  -,  -
06:20:19,  22819,     047%,     00:-1,         3779,     -,  -,  -
06:21:19,  22879,     047%,     00:-1,         3779,     -,  -,  -
06:22:19,  22939,     047%,     00:-1,         3778,     -,  -,  -
06:23:19,  22999,     047%,     00:-1,         3778,     -,  -,  -
06:24:19,  23059,     047%,     00:-1,         3777,     -,  -,  -
06:25:19,  23119,     047%,     00:-1,         3777,     -,  -,  -
06:26:19,  23179,     047%,     00:-1,         3777,     -,  -,  -
06:27:19,  23239,     046%,     00:-1,         3775,     -,  -,  -
06:28:19,  23299,     046%,     00:-1,         3775,     -,  -,  -
06:29:19,  23359,     046%,     00:-1,         3774,     -,  -,  -
06:30:19,  23419,     046%,     00:-1,         3774,     -,  -,  -
06:31:19,  23479,     046%,     00:-1,         3774,     -,  -,  -
06:32:19,  23539,     046%,     00:-1,         3774,     -,  -,  -
06:33:19,  23599,     046%,     00:-1,         3773,     -,  -,  -
06:34:19,  23659,     046%,     00:-1,         3773,     -,  -,  -
06:35:19,  23719,     045%,     00:-1,         3772,     -,  -,  -
06:36:19,  23779,     045%,     00:-1,         3772,     -,  -,  -
06:37:19,  23839,     045%,     00:-1,         3771,     -,  -,  -
06:38:19,  23899,     045%,     00:-1,         3770,     -,  -,  -
06:39:19,  23959,     045%,     00:-1,         3771,     -,  -,  -
06:40:19,  24019,     045%,     00:-1,         3770,     -,  -,  -
06:41:19,  24079,     045%,     00:-1,         3770,     -,  -,  -
06:42:19,  24139,     044%,     00:-1,         3769,     -,  -,  -
06:43:19,  24199,     044%,     00:-1,         3769,     -,  -,  -
06:44:19,  24259,     044%,     00:-1,         3768,     -,  -,  -
06:45:19,  24319,     044%,     00:-1,         3768,     -,  -,  -
06:46:19,  24379,     044%,     00:-1,         3768,     -,  -,  -
06:47:19,  24439,     044%,     00:-1,         3768,     -,  -,  -
06:48:19,  24499,     044%,     00:-1,         3767,     -,  -,  -
06:49:19,  24559,     043%,     00:-1,         3766,     -,  -,  -
06:50:19,  24619,     043%,     00:-1,         3766,     -,  -,  -
06:51:19,  24679,     043%,     00:-1,         3766,     -,  -,  -
06:52:19,  24739,     043%,     00:-1,         3765,     -,  -,  -
06:53:19,  24799,     043%,     00:-1,         3766,     -,  -,  -
06:54:19,  24859,     043%,     00:-1,         3765,     -,  -,  -
06:55:19,  24919,     043%,     00:-1,         3765,     -,  -,  -
06:56:19,  24979,     043%,     00:-1,         3764,     -,  -,  -
06:57:19,  25039,     043%,     00:-1,         3763,     -,  -,  -
06:58:19,  25099,     043%,     00:-1,         3763,     -,  -,  -
06:59:19,  25159,     043%,     00:-1,         3763,     -,  -,  -
07:00:19,  25219,     043%,     00:-1,         3763,     -,  -,  -
07:01:19,  25279,     043%,     00:-1,         3763,     -,  -,  -
07:02:19,  25339,     043%,     00:-1,         3763,     -,  -,  -
07:03:19,  25399,     042%,     00:-1,         3762,     -,  -,  -
07:04:19,  25459,     042%,     00:-1,         3762,     -,  -,  -
07:05:19,  25519,     042%,     00:-1,         3762,     -,  -,  -
07:06:19,  25579,     042%,     00:-1,         3761,     -,  -,  -
07:07:19,  25639,     042%,     00:-1,         3762,     -,  -,  -
07:08:19,  25699,     042%,     00:-1,         3760,     -,  -,  -
07:09:19,  25759,     042%,     00:-1,         3761,     -,  -,  -
07:10:19,  25819,     042%,     00:-1,         3760,     -,  -,  -
07:11:19,  25879,     042%,     00:-1,         3760,     -,  -,  -
07:12:19,  25939,     041%,     00:-1,         3759,     -,  -,  -
07:13:19,  25999,     042%,     00:-1,         3760,     -,  -,  -
07:14:19,  26059,     041%,     00:-1,         3759,     -,  -,  -
07:15:19,  26119,     041%,     00:-1,         3759,     -,  -,  -
07:16:19,  26179,     041%,     00:-1,         3759,     -,  -,  -
07:17:19,  26239,     041%,     00:-1,         3759,     -,  -,  -
07:18:19,  26299,     041%,     00:-1,         3758,     -,  -,  -
07:19:19,  26359,     041%,     00:-1,         3758,     -,  -,  -
07:20:19,  26419,     041%,     00:-1,         3758,     -,  -,  -
07:21:19,  26479,     041%,     00:-1,         3757,     -,  -,  -
07:22:19,  26539,     041%,     00:-1,         3757,     -,  -,  -
07:23:19,  26599,     041%,     00:-1,         3757,     -,  -,  -
07:24:19,  26659,     041%,     00:-1,         3757,     -,  -,  -
07:25:19,  26719,     040%,     00:-1,         3756,     -,  -,  -
07:26:19,  26779,     041%,     00:-1,         3757,     -,  -,  -
07:27:19,  26839,     040%,     00:-1,         3756,     -,  -,  -
07:28:19,  26899,     040%,     00:-1,         3756,     -,  -,  -
07:29:19,  26959,     040%,     00:-1,         3756,     -,  -,  -
07:30:19,  27019,     040%,     00:-1,         3755,     -,  -,  -
07:31:19,  27079,     040%,     00:-1,         3756,     -,  -,  -
07:32:19,  27139,     040%,     00:-1,         3755,     -,  -,  -
07:33:19,  27199,     040%,     00:-1,         3756,     -,  -,  -
07:34:19,  27259,     040%,     00:-1,         3755,     -,  -,  -
07:35:19,  27319,     040%,     00:-1,         3755,     -,  -,  -
07:36:19,  27379,     040%,     00:-1,         3754,     -,  -,  -
07:37:19,  27439,     040%,     00:-1,         3755,     -,  -,  -
07:38:19,  27499,     040%,     00:-1,         3754,     -,  -,  -
07:39:19,  27559,     040%,     00:-1,         3754,     -,  -,  -
07:40:19,  27619,     040%,     00:-1,         3754,     -,  -,  -
07:41:19,  27679,     040%,     00:-1,         3753,     -,  -,  -
07:42:19,  27739,     040%,     00:-1,         3754,     -,  -,  -
07:43:19,  27799,     040%,     00:-1,         3753,     -,  -,  -
07:44:19,  27859,     040%,     00:-1,         3753,     -,  -,  -
07:45:19,  27919,     040%,     00:-1,         3753,     -,  -,  -
07:46:19,  27979,     040%,     00:-1,         3753,     -,  -,  -
07:47:19,  28039,     040%,     00:-1,         3753,     -,  -,  -
07:48:19,  28099,     039%,     00:-1,         3752,     -,  -,  -
07:49:19,  28159,     040%,     00:-1,         3753,     -,  -,  -
07:50:19,  28219,     039%,     00:-1,         3752,     -,  -,  -
07:51:19,  28279,     040%,     00:-1,         3753,     -,  -,  -
07:52:19,  28339,     039%,     00:-1,         3752,     -,  -,  -
07:53:19,  28399,     039%,     00:-1,         3752,     -,  -,  -
07:54:19,  28459,     039%,     00:-1,         3751,     -,  -,  -
07:55:19,  28519,     039%,     00:-1,         3751,     -,  -,  -
07:56:19,  28579,     039%,     00:-1,         3752,     -,  -,  -
07:57:19,  28639,     039%,     00:-1,         3751,     -,  -,  -
07:58:19,  28699,     039%,     00:-1,         3752,     -,  -,  -
07:59:19,  28759,     039%,     00:-1,         3751,     -,  -,  -
08:00:19,  28819,     039%,     00:-1,         3751,     -,  -,  -
08:01:19,  28879,     039%,     00:-1,         3751,     -,  -,  -
08:02:19,  28939,     038%,     00:-1,         3750,     -,  -,  -
08:03:19,  28999,     039%,     00:-1,         3751,     -,  -,  -
08:04:19,  29059,     038%,     00:-1,         3749,     -,  -,  -
08:05:19,  29119,     038%,     00:-1,         3750,     -,  -,  -
08:06:19,  29179,     038%,     00:-1,         3749,     -,  -,  -
08:07:19,  29239,     038%,     00:-1,         3750,     -,  -,  -
08:08:19,  29299,     038%,     00:-1,         3749,     -,  -,  -
08:09:19,  29359,     038%,     00:-1,         3750,     -,  -,  -
08:10:19,  29419,     038%,     00:-1,         3749,     -,  -,  -
08:11:19,  29479,     038%,     00:-1,         3749,     -,  -,  -
08:12:19,  29539,     038%,     00:-1,         3749,     -,  -,  -
08:13:19,  29599,     038%,     00:-1,         3749,     -,  -,  -
08:14:19,  29659,     037%,     00:-1,         3748,     -,  -,  -
08:15:19,  29719,     037%,     00:-1,         3748,     -,  -,  -
08:16:19,  29779,     037%,     00:-1,         3747,     -,  -,  -
08:17:19,  29839,     037%,     00:-1,         3747,     -,  -,  -
08:18:19,  29899,     037%,     00:-1,         3747,     -,  -,  -
08:19:19,  29959,     037%,     00:-1,         3747,     -,  -,  -
08:20:19,  30019,     037%,     00:-1,         3747,     -,  -,  -
08:21:19,  30079,     036%,     00:-1,         3746,     -,  -,  -
08:22:19,  30139,     037%,     00:-1,         3747,     -,  -,  -
08:23:19,  30199,     036%,     00:-1,         3745,     -,  -,  -
08:24:19,  30259,     036%,     00:-1,         3746,     -,  -,  -
08:25:19,  30319,     036%,     00:-1,         3745,     -,  -,  -
08:26:19,  30379,     036%,     00:-1,         3745,     -,  -,  -
08:27:19,  30439,     036%,     00:-1,         3744,     -,  -,  -
08:28:19,  30499,     036%,     00:-1,         3745,     -,  -,  -
08:29:19,  30559,     036%,     00:-1,         3744,     -,  -,  -
08:30:19,  30619,     036%,     00:-1,         3745,     -,  -,  -
08:31:19,  30679,     036%,     00:-1,         3744,     -,  -,  -
08:32:19,  30739,     036%,     00:-1,         3744,     -,  -,  -
08:33:19,  30799,     035%,     00:-1,         3743,     -,  -,  -
08:34:19,  30859,     035%,     00:-1,         3743,     -,  -,  -
08:35:19,  30919,     035%,     00:-1,         3742,     -,  -,  -
08:36:19,  30979,     035%,     00:-1,         3743,     -,  -,  -
08:37:19,  31039,     035%,     00:-1,         3743,     -,  -,  -
08:38:19,  31099,     035%,     00:-1,         3742,     -,  -,  -
08:39:19,  31159,     035%,     00:-1,         3742,     -,  -,  -
08:40:19,  31219,     034%,     00:-1,         3741,     -,  -,  -
08:41:19,  31279,     034%,     00:-1,         3741,     -,  -,  -
08:42:19,  31339,     034%,     00:-1,         3740,     -,  -,  -
08:43:19,  31399,     034%,     00:-1,         3740,     -,  -,  -
08:44:19,  31459,     034%,     00:-1,         3740,     -,  -,  -
08:45:19,  31519,     033%,     00:-1,         3738,     -,  -,  -
08:46:19,  31579,     033%,     00:-1,         3739,     -,  -,  -
08:47:19,  31639,     033%,     00:-1,         3738,     -,  -,  -
08:48:19,  31699,     033%,     00:-1,         3738,     -,  -,  -
08:49:19,  31759,     032%,     00:-1,         3736,     -,  -,  -
08:50:19,  31819,     033%,     00:-1,         3737,     -,  -,  -
08:51:19,  31879,     032%,     00:-1,         3736,     -,  -,  -
08:52:19,  31939,     032%,     00:-1,         3736,     -,  -,  -
08:53:19,  31999,     032%,     00:-1,         3735,     -,  -,  -
08:54:19,  32059,     031%,     00:-1,         3734,     -,  -,  -
08:55:19,  32119,     031%,     00:-1,         3734,     -,  -,  -
08:56:19,  32179,     031%,     00:-1,         3734,     -,  -,  -
08:57:19,  32239,     031%,     00:-1,         3733,     -,  -,  -
08:57:26,  32246,     030%,     00:-1,         3732,     -,  -,  -
08:58:26,  32306,     031%,     00:-1,         3733,     -,  -,  -
08:59:26,  32366,     030%,     00:-1,         3731,     -,  -,  -
09:00:26,  32426,     030%,     00:-1,         3731,     -,  -,  -
09:01:26,  32486,     030%,     00:-1,         3730,     -,  -,  -
09:02:26,  32546,     030%,     00:-1,         3730,     -,  -,  -
09:03:26,  32606,     029%,     00:-1,         3729,     -,  -,  -
09:04:26,  32666,     029%,     00:-1,         3728,     -,  -,  -
09:05:26,  32726,     029%,     00:-1,         3728,     -,  -,  -
09:06:26,  32786,     028%,     00:-1,         3727,     -,  -,  -
09:07:26,  32846,     028%,     00:-1,         3726,     -,  -,  -
09:08:26,  32906,     028%,     00:-1,         3726,     -,  -,  -
09:09:26,  32966,     028%,     00:-1,         3725,     -,  -,  -
09:10:26,  33026,     028%,     00:-1,         3725,     -,  -,  -
09:11:26,  33086,     027%,     00:-1,         3723,     -,  -,  -
09:12:26,  33146,     027%,     00:-1,         3723,     -,  -,  -
09:13:26,  33206,     026%,     00:-1,         3722,     -,  -,  -
09:14:26,  33266,     026%,     00:-1,         3722,     -,  -,  -
09:15:26,  33326,     026%,     00:-1,         3720,     -,  -,  -
09:16:26,  33386,     026%,     00:-1,         3720,     -,  -,  -
09:17:26,  33446,     025%,     00:-1,         3719,     -,  -,  -
09:18:26,  33506,     025%,     00:-1,         3719,     -,  -,  -
09:19:26,  33566,     025%,     00:-1,         3718,     -,  -,  -
09:20:26,  33626,     025%,     00:-1,         3717,     -,  -,  -
09:21:26,  33686,     024%,     00:-1,         3716,     -,  -,  -
09:22:26,  33746,     024%,     00:-1,         3715,     -,  -,  -
09:23:26,  33806,     023%,     00:-1,         3714,     -,  -,  -
09:24:26,  33866,     023%,     00:-1,         3713,     -,  -,  -
09:25:26,  33926,     023%,     00:-1,         3713,     -,  -,  -
09:26:26,  33986,     023%,     00:-1,         3712,     -,  -,  -
09:27:26,  34046,     022%,     00:-1,         3711,     -,  -,  -
09:28:26,  34106,     021%,     00:-1,         3709,     -,  -,  -
09:29:26,  34166,     021%,     00:-1,         3709,     -,  -,  -
09:30:26,  34226,     021%,     00:-1,         3708,     -,  -,  -
09:31:26,  34286,     021%,     00:-1,         3707,     -,  -,  -
09:32:26,  34346,     020%,     00:-1,         3705,     -,  -,  -
09:33:26,  34406,     020%,     00:-1,         3705,     -,  -,  -
09:34:26,  34466,     019%,     00:-1,         3703,     -,  -,  -
09:35:26,  34526,     019%,     00:-1,         3702,     -,  -,  -
09:36:26,  34586,     019%,     00:-1,         3700,     -,  -,  -
09:37:26,  34646,     019%,     00:-1,         3700,     -,  -,  -
09:38:26,  34706,     018%,     00:-1,         3698,     -,  -,  -
09:39:26,  34766,     018%,     00:-1,         3697,     -,  -,  -
09:40:26,  34826,     018%,     00:-1,         3696,     -,  -,  -
09:41:26,  34886,     018%,     00:-1,         3695,     -,  -,  -
09:42:26,  34946,     017%,     00:-1,         3693,     -,  -,  -
09:43:26,  35006,     017%,     00:-1,         3692,     -,  -,  -
09:44:26,  35066,     017%,     00:-1,         3691,     -,  -,  -
09:45:26,  35126,     017%,     00:-1,         3689,     -,  -,  -
09:46:26,  35186,     016%,     00:-1,         3687,     -,  -,  -
09:47:26,  35246,     016%,     00:-1,         3686,     -,  -,  -
09:48:26,  35306,     016%,     00:-1,         3684,     -,  -,  -
09:48:29,  35309,     015%,     00:-1,         3683,     -,  -,  -
09:49:29,  35369,     015%,     00:-1,         3682,     -,  -,  -
09:50:29,  35429,     015%,     00:-1,         3681,     -,  -,  -
09:51:29,  35489,     015%,     00:-1,         3679,     -,  -,  -
09:52:29,  35549,     014%,     00:-1,         3677,     -,  -,  -
09:53:29,  35609,     014%,     00:-1,         3676,     -,  -,  -
09:54:29,  35669,     014%,     00:-1,         3674,     -,  -,  -
09:55:29,  35729,     013%,     00:-1,         3672,     -,  -,  -
09:56:29,  35789,     013%,     00:-1,         3672,     -,  -,  -
09:57:29,  35849,     013%,     00:-1,         3670,     -,  -,  -
09:58:29,  35909,     013%,     00:-1,         3669,     -,  -,  -
09:59:29,  35969,     013%,     00:-1,         3668,     -,  -,  -
10:00:29,  36029,     013%,     00:-1,         3668,     -,  -,  -
10:01:29,  36089,     012%,     00:-1,         3667,     -,  -,  -
10:02:29,  36149,     012%,     00:-1,         3666,     -,  -,  -
10:03:29,  36209,     012%,     00:-1,         3666,     -,  -,  -
10:04:29,  36269,     012%,     00:-1,         3665,     -,  -,  -
10:05:29,  36329,     012%,     00:-1,         3664,     -,  -,  -
10:06:29,  36389,     012%,     00:-1,         3664,     -,  -,  -
10:07:29,  36449,     012%,     00:-1,         3663,     -,  -,  -
10:08:29,  36509,     012%,     00:-1,         3663,     -,  -,  -
10:09:29,  36569,     012%,     00:-1,         3663,     -,  -,  -
10:10:29,  36629,     011%,     00:-1,         3662,     -,  -,  -
10:11:29,  36689,     011%,     00:-1,         3662,     -,  -,  -
10:12:29,  36749,     011%,     00:-1,         3660,     -,  -,  -
10:13:29,  36809,     011%,     00:-1,         3660,     -,  -,  -
10:14:29,  36869,     011%,     00:-1,         3659,     -,  -,  -
10:15:29,  36929,     011%,     00:-1,         3658,     -,  -,  -
10:16:29,  36989,     010%,     00:-1,         3657,     -,  -,  -
10:17:29,  37049,     010%,     00:-1,         3656,     -,  -,  -
10:18:29,  37109,     010%,     00:-1,         3655,     -,  -,  -
10:19:29,  37169,     010%,     00:-1,         3655,     -,  -,  -
10:20:29,  37229,     010%,     00:-1,         3655,     -,  -,  -
10:21:29,  37289,     010%,     00:-1,         3653,     -,  -,  -
10:22:29,  37349,     010%,     00:-1,         3653,     -,  -,  -
10:23:29,  37409,     010%,     00:-1,         3652,     -,  -,  -
10:24:29,  37469,     010%,     00:-1,         3652,     -,  -,  -
10:25:29,  37529,     009%,     00:-1,         3650,     -,  -,  -
10:26:29,  37589,     009%,     00:-1,         3649,     -,  -,  -
10:27:29,  37649,     009%,     00:-1,         3648,     -,  -,  -
10:28:29,  37709,     009%,     00:-1,         3646,     -,  -,  -
10:29:29,  37769,     009%,     00:-1,         3644,     -,  -,  -
10:30:29,  37829,     009%,     00:-1,         3642,     -,  -,  -
10:31:29,  37889,     009%,     00:-1,         3640,     -,  -,  -
10:32:29,  37949,     009%,     00:-1,         3638,     -,  -,  -
10:33:29,  38009,     009%,     00:-1,         3635,     -,  -,  -
10:34:29,  38069,     009%,     00:-1,         3632,     -,  -,  -
10:35:29,  38129,     009%,     00:-1,         3629,     -,  -,  -
10:36:29,  38189,     009%,     00:-1,         3625,     -,  -,  -
10:37:29,  38249,     009%,     00:-1,         3622,     -,  -,  -
10:38:29,  38309,     009%,     00:-1,         3618,     -,  -,  -
10:39:29,  38369,     008%,     00:-1,         3616,     -,  -,  -
10:40:29,  38429,     008%,     00:-1,         3611,     -,  -,  -
10:41:29,  38489,     008%,     00:-1,         3609,     -,  -,  -
10:42:29,  38549,     008%,     00:-1,         3605,     -,  -,  -
10:43:29,  38609,     008%,     00:-1,         3603,     -,  -,  -
10:44:29,  38669,     008%,     00:-1,         3599,     -,  -,  -
10:45:29,  38729,     008%,     00:-1,         3595,     -,  -,  -
10:46:29,  38789,     008%,     00:-1,         3593,     -,  -,  -
10:47:29,  38849,     008%,     00:-1,         3589,     -,  -,  -
10:48:29,  38909,     008%,     00:-1,         3586,     -,  -,  -
10:49:29,  38969,     008%,     00:-1,         3582,     -,  -,  -
10:50:29,  39029,     007%,     00:-1,         3580,     -,  -,  -
10:51:29,  39089,     007%,     00:-1,         3577,     -,  -,  -
10:52:29,  39149,     007%,     00:-1,         3574,     -,  -,  -
10:53:29,  39209,     007%,     00:-1,         3571,     -,  -,  -
10:54:29,  39269,     007%,     00:-1,         3567,     -,  -,  -
10:55:29,  39329,     007%,     00:-1,         3564,     -,  -,  -
10:56:29,  39389,     007%,     00:-1,         3560,     -,  -,  -
10:57:29,  39449,     007%,     00:-1,         3558,     -,  -,  -
10:58:29,  39509,     007%,     00:-1,         3554,     -,  -,  -
10:59:29,  39569,     007%,     00:-1,         3551,     -,  -,  -
11:00:29,  39629,     007%,     00:-1,         3547,     -,  -,  -
11:01:29,  39689,     006%,     00:-1,         3544,     -,  -,  -
11:02:29,  39749,     006%,     00:-1,         3540,     -,  -,  -
11:03:29,  39809,     006%,     00:-1,         3538,     -,  -,  -
11:04:29,  39869,     006%,     00:-1,         3534,     -,  -,  -
11:05:29,  39929,     006%,     00:-1,         3531,     -,  -,  -
11:06:29,  39989,     006%,     00:-1,         3527,     -,  -,  -
11:07:29,  40049,     006%,     00:-1,         3523,     -,  -,  -
11:08:29,  40109,     006%,     00:-1,         3520,     -,  -,  -
11:09:29,  40169,     006%,     00:-1,         3515,     -,  -,  -
11:10:29,  40229,     006%,     00:-1,         3512,     -,  -,  -
11:10:37,  40237,     005%,     00:-1,         3511,     -,  -,  -
11:11:37,  40297,     005%,     00:-1,         3508,     -,  -,  -
11:12:37,  40357,     005%,     00:-1,         3504,     -,  -,  -
11:13:37,  40417,     005%,     00:-1,         3500,     -,  -,  -
11:14:37,  40477,     005%,     00:-1,         3498,     -,  -,  -
11:15:37,  40537,     005%,     00:-1,         3494,     -,  -,  -
11:16:37,  40597,     005%,     00:-1,         3492,     -,  -,  -
11:17:37,  40657,     005%,     00:-1,         3488,     -,  -,  -
11:18:37,  40717,     005%,     00:-1,         3486,     -,  -,  -
11:19:37,  40777,     005%,     00:-1,         3482,     -,  -,  -
11:20:37,  40837,     005%,     00:-1,         3480,     -,  -,  -
11:21:37,  40897,     005%,     00:-1,         3477,     -,  -,  -
11:22:37,  40957,     004%,     00:-1,         3474,     -,  -,  -
11:23:37,  41017,     004%,     00:-1,         3472,     -,  -,  -
11:24:37,  41077,     004%,     00:-1,         3469,     -,  -,  -
11:25:37,  41137,     004%,     00:-1,         3466,     -,  -,  -
11:26:37,  41197,     004%,     00:-1,         3464,     -,  -,  -
11:27:37,  41257,     004%,     00:-1,         3460,     -,  -,  -
11:28:37,  41317,     004%,     00:-1,         3457,     -,  -,  -
11:29:37,  41377,     004%,     00:-1,         3453,     -,  -,  -
11:30:37,  41437,     004%,     00:-1,         3451,     -,  -,  -
11:31:37,  41497,     004%,     00:-1,         3447,     -,  -,  -
11:32:37,  41557,     004%,     00:-1,         3444,     -,  -,  -
11:33:37,  41617,     003%,     00:-1,         3439,     -,  -,  -
11:34:37,  41677,     003%,     00:-1,         3435,     -,  -,  -
11:35:37,  41737,     003%,     00:-1,         3430,     -,  -,  -
11:36:37,  41797,     003%,     00:-1,         3426,     -,  -,  -
11:37:37,  41857,     003%,     00:-1,         3419,     -,  -,  -
11:38:37,  41917,     003%,     00:-1,         3414,     -,  -,  -
11:39:37,  41977,     003%,     00:-1,         3408,     -,  -,  -
11:40:37,  42037,     002%,     00:-1,         3400,     -,  -,  -
11:41:37,  42097,     002%,     00:-1,         3392,     -,  -,  -
11:42:37,  42157,     002%,     00:-1,         3382,     -,  -,  -
11:43:37,  42217,     002%,     00:-1,         3372,     -,  -,  -
11:44:37,  42277,     001%,     00:-1,         3360,     -,  -,  -
11:45:37,  42337,     001%,     00:-1,         3347,     -,  -,  -
11:46:37,  42397,     000%,     00:-1,         3334,     -,  -,  -
11:47:37,  42457,     000%,     00:-1,         3319,     -,  -,  -
11:48:37,  42517,     000%,     00:-1,         3303,     -,  -,  -
--Battery bench ended, reason: power off--
Guys here's my bench, with nearly 12h on continous playing. So the problem exist only when you start to skip a lot, damn.
Jun 23, 2016 at 4:49 PM Post #3,489 of 5,194
Even if Rockbox was hardcoded to expect a certain capacity on the battery, then the bigger/larger capacity batteries would last however much longer, so it would take longer for the battery meter to knock off another %. The real problem is Rockbox isn't designed for any one player so some players show no difference in battery life with Rockbox and some show a lot of difference.
It's like installing Linux on a laptop: yes it'll still run on battery but probably not as well/accurate as an OS that was designed for the machine.
So you might get an extra hour or two using the intended OS instead of one that has a catch-all battery function (rockbox)?
That analogy might not help either though...
Jun 23, 2016 at 7:18 PM Post #3,490 of 5,194
Like I said, runtime estimation is not implemented, so it can't estimate how much time you have left.
# 2) Set to repeat.
I don't think how often you skip tracks will have much effect.  12 hours from a 1500 mah battery is 125 mA.  All the software running on the device probably only uses a tiny fraction of that.  Have you tested the stock firmware?
The size of the battery only determines how long the player will run, not how much power it requires to run at any given instant.
Jun 24, 2016 at 2:44 AM Post #3,491 of 5,194
......I'm pretty impressed with the Opus-Audio Opus#1 reviews and the companies willingness to fix firmware errors, might be my
next 'upgrade'.
Unfortunately not everybody owns a mansion in Beverly Hills and a alpine lodge in Aspen... Opus-Audio Opus no.1 £449 vs. XDUOO X3 £70 (prices off Amazon UK)
Actually you are right, I'm going to ditch my Ford Mondeo for an Aston Martin... I heard they are much faster... :cool:
Jun 24, 2016 at 2:48 AM Post #3,492 of 5,194
you dont need to own a beverly ills mansion to afford these.... heck kids working in my local mcdonalds make enough to get those with a bit of saving. Not a fair comparison with the aston martin
Jun 24, 2016 at 3:16 AM Post #3,493 of 5,194
Ah that makes sense now.
Well I don't know how to bench it properly, I mean I could leave it playing but I won't now exactly how much time will it take to fully discharge, but I think will be almost the same as rockbox.
Jun 24, 2016 at 6:17 AM Post #3,494 of 5,194
you dont need to own a beverly ills mansion to afford these.... heck kids working in my local mcdonalds make enough to get those with a bit of saving. Not a fair comparison with the aston martin :rolleyes:
still less than any flagship phone, and would have more value after 2 years ;) I remember getting my iPhone 5 for almost 600€ and if i Try to Sell it off it would fetch me around 150 at the max. I had a fiio x3 bought at the same time, for around 250€. I sold 6 months back for 120€. ;)
Jun 24, 2016 at 7:49 AM Post #3,495 of 5,194
When I look at spec's for the Opus-Audio it's relatively inexpensive compared to the others (A&K for example) with the same
features.
and I sure as hell don't own a beverly hills mansion, nor an Aston Martin, I drive a Honda Fit (Jazz in Europe/Asia), I did fly over Aspen once.
I have no issue with other folks who have multiple DAPs, can afford the A&K 380 cu (about $3000), and spend thousands on IEMs
if they can afford it, more power to them, no need to get snarky about it.
