Gabbbbbbbbbbbb
- Feb 16, 2013
I do have one. But sadly I don't understand what needs to be done!
Just apply solder where indicated, not sure about the bottom arrows, I have not found a better photo, but you should see it clearly with your own opened up player.
Just hoping that the factory applied solder would bond again with just heat was not enough for me, but you could get lucky. I used a lot of solder & the end result looks pretty ugly, but the jack not only worked again, but also it feels really tight & solid now.
Alternatively you can just use the far superior Rockbox firmware, it can do volume controlled line out, so essentially you have a spare jack out for your IEMs.
