XDuoo X3 DSD 24Bit / 192KHz CS4398 Chip Lossless Music Player
Aug 14, 2019 at 7:20 AM Post #5,161 of 5,194
That sounds great, now if only somebody could fix the display issue where it's useless in daylight I could fully enjoy this DAP haha. It sounds great and has plenty of power but display is terrible and battery is just OK.
This is the matter of screen cover - these plastic is really dim. I have managed to dismount it and attach a cover cut off the DS Lite Screen Protector.
Here you can read about it.
https://www.head-fi.org/threads/rockbox-xduoo-x3.803844/page-137
Aug 14, 2019 at 11:00 AM Post #5,162 of 5,194
Correct, here’s my How2. It’s very easy to follow:
https://www.head-fi.org/threads/rockbox-xduoo-x3.803844/page-101#post-13376076
Aug 14, 2019 at 11:15 AM Post #5,163 of 5,194
Aug 14, 2019 at 12:58 PM Post #5,164 of 5,194
I think it's easier to simply dissassemble the DAP (only 2 Torx screws) and then push the cover out instead of using razor and risking soem scratches.
But yeah, this DS Lite Screen Protector is perfect for this topic.
A number of people have sheared off their volume buttons when trying to remove or replace the circuit board. That renders the X3 100% broken.
If a razor blade is used as my How2 instructed, there is minimal to no risk of problems. However, removing the circuit board, there is a risk of problems.
But it is up to each individual to decide what method is easiest and safest.
Aug 15, 2019 at 2:44 AM Post #5,165 of 5,194
hi,
just spotted talk of the VTX5 firmware ... what does this do ? and do you install using the same method as rockbox?
and is windows 7 still necessary, anyone had any success with 10?
cheers
Sep 7, 2019 at 11:41 PM Post #5,168 of 5,194
What have people upgraded to from the x3? My battery life is shot on the x3 and I had not used my ibasso dx50 for a while and it will not charge properly either. Is the new x3 mark 2 a worthy upgrade?
Sep 8, 2019 at 4:24 PM Post #5,169 of 5,194
Seems like it would be, and it is cheaper than the predecessor. For want of trying something new I bought the Hidizs AP80 but my old X2 was a great player for what it did. XDuoo is a great value proposition.
Dec 16, 2019 at 8:12 PM Post #5,170 of 5,194
Dec 22, 2019 at 5:37 AM Post #5,172 of 5,194
Have not been here for ages... what is this VTX5 firmware..? Does it cure the pitch problem? Where can I download it?
May 29, 2021 at 2:55 PM Post #5,173 of 5,194
Hello, regarding this VTX5 version, is this worth it if I already have a fine-working X3 with rockbox? For instance, is there an upgrade in terms of sound quality?
From what I understand from Vortex's post, I need to flash my rockboxed X3 with the VTX5 version (an altered version of the stock), and then install rockbox after that?
If this still requires a Windows 7 machine, then it really sucks. Unless I don't really stand to gain from the VTX5 upgrade.
May 29, 2021 at 9:49 PM Post #5,174 of 5,194
Rockbox tweak is only needed for early X3 that has fiemware 1.0, which has pitch issue for certain audio sampling rate.. (Browse it.. I already forgot which rate)
But firmware 1.1 already fix this issue.
Unless you love Rockbox, the use VTX5 + Rockbox is not mandatory anymore..
Jun 2, 2021 at 10:01 AM Post #5,175 of 5,194
Thank you for the reply. I tried updating it to VTX5 with the "update" file and entering the stock firmware menu. When I pressed on "upgrade", it did nothing other than starting up my rockbox firmware instead. So, the manual update will be needed, something that I'm not able to do with W10.
I don't think that I will spend more time dealing with this. Probably better to look for an actual upgrade in DAP.
