XDuoo X3 DSD 24Bit / 192KHz CS4398 Chip Lossless Music Player
May 7, 2016 at 3:12 PM Post #3,167 of 5,194
Not really... the only slowdown I experience is if I try to open a really huge directory (150+ directories inside it.... i need to organize better
) but it just hangs for a few seconds and then eventually loads the folder, it's never failed to load, just takes a bit on bigger folders it seems, if that's what you mean...
But then again I remember when 4mhz was fast for a computer, so it's all relative I guess.
May 8, 2016 at 6:28 AM Post #3,171 of 5,194
  Thanks.
But, with Rock box, is need to format the SD card on FAT32?
PS. To purchase it there are two options:
1) xDuoo x3 at $ 88
2) x3+LZ 02A at $ 105
Which one is better?
Depends on your needs. If you wanna have a new pair of earphones... the second deal would probably be the best, otherwise go with the first option.
May 8, 2016 at 7:48 AM Post #3,176 of 5,194
May 8, 2016 at 9:19 AM Post #3,179 of 5,194
Thanks!
PS. (OT) Can I ask you the differences between AKG K712 Pro and HiFiMan HE-400i? The HE-400i is better then HD650? And between Shure SRH840 and NAD HP50? …I have Akg and Nad… (also by MP for OT)
The HE-400i are a step forward from the AKG 712 all over the range, including a better bass that goes way down/deeper than the AKG, much much forward and airy mids, better imaging, better instrument separation, more refined, coherent and natural sound. That being said, the 400i are much heavier so YMMV.
Silver is my favorite :)
May 8, 2016 at 9:40 AM Post #3,180 of 5,194
Wow, very interesting!
The 400i is to have or 400s is still good?
Therefore go for silver!
