redfx
- May 30, 2014
The casing of the 3.5mm jack was ripped off my Ostry KC06,by the extra tight X2
So is everyone's headphone jack as tight fitting as mine is? I'm a bit worried about it breaking from the force needed to remove them.
My X2's jack is just a little more tight compared to my laptop, or phone. But nothing extraordinary.
I only have to put efforts while inserting TTPOD T1E in it. Maybe that one has tad more diameter than others.
Yeah, it seems the KZ ed9's plug must be a bit oversize, my JVC HA-FX40s go in & out without extra effort. Guess I'll need to either leave them connected or be careful when removing them.
Sorry, if it's been answered before in this thread, but how much battery run-time do you get from your x2 playing FLACs in 16/44.1? I only get around 4-5 hours (using a 16-ohms audio-technica CM700Ti), so I'm wondering if my battery is faulty.
