Yup ....the synergy of pairing the right iem and dap is important and the other thing for me is tip rolling .....
Take the leap of faith is bound by me wallet atm ....haha
Yup ....the synergy of pairing the right iem and dap is important and the other thing for me is tip rolling .....![]()
I'll let you guys in on a little secret - Havi B3 PRO 1 / XDuoo X2.![]()
Aaaaah I guess I'm not on the fence about buying the X2 anymore... I'm still saving up for the Fiio X1, but the X2 will definitely be the next DAP I buy.
If its for Havi definitely take the XDuoo and save a few dollars in the process.
>> Warning: xDuoo X2 support *.flac only 16bit/44.1kHz and may not support special symbols in tags. And may not support tag "Comment". Use special tools to fix this.
Grrrrrrrr I sure look forward to striping tags off 120gb of flac files via mp3tag or dbpoweramp
Any firmware fixes or future options to ignore tags and ETAs?
I'm planning on getting both, but right now I don't have a dedicated DAP, I'm using my iPhone 6+. Would you recommend getting the X2 first and then the X1 in this case?
Re mp3tag true but. Most of my folders don't play and I like tags on windows(album art etc) so I world prefer an ignore tag option
They can fix their firmware or at least add an ignore tags option
You Probs cleaned of tags much earlier for other players
You should be ok, most folders have been playing without a fuss, there is the occasional time we've needed to remove tags. I wouldn't go as far to say you need to remove 120gb worth of tags although a separate card for your X2 may be a nice option to consider. And if it comes to removing tags MP3tag will do an entire batch in one go, that entire card, (you won't need to load each album individually into the program).
I wouldn't worry yet svyr, apart from the occasional hicup things are pretty smooth.
Yes, I would recommend X2 first, particularly if the source is for Havi.
Yes got it and titan1. I suspect dbpa and the CD info source libraries populate the tag info it hates
Titan is really really good thanks
Lol, I don't want more SD cards or selectively copying music
I want people not to support tags at all or add an ignore option for tags if they can't write parsers
