dpeterfy32
TyLinear power supply Nichicon. Elna caps.
My experience is when I change to usb mode to Bluetooth mode. When switch back to usb mode, it cannot link to PC. Have to power off and on again for it to link to PCSometimes my usb connection will just unlink for no reason. After powering it down, it seems to connect again.
Anyone else have this or know why it would be happening?
Windows 10 error.Sometimes my usb connection will just unlink for no reason. After powering it down, it seems to connect again.
my situation is using phone as source. It seems to happen after hours of listening, think the TA-22 gets to hot? When I turn off to cool down and wait a bit and turn back on, it connects again.Windows 10 error.
It stops recognizing the USB, go into settings and force windows to accept the T22 as a fixed device, this solves the problem.
Cant comment on A&K SR15 as I nv use before. I’m currently using HD650 and focal clear on TA22. I swapped the tubes to RCA clear top. I find that HD650 sounds a lot better with TA-22 compared to my ifi hip dac2. I find that tubes are pretty important, the default tubes doesnt suit my taste, I changed to RCA clear top and it has larger soundstage and better mids and highs.Hi!
I am considering something like ta22 but really anything with tube and a bluetooth receiver to stream from tidal on the phone, or to attach the qudelix or a dap as a source.
I wonder how sound would compare to my A&K SR15, would it be the same or an important improvement?
I would mainly connect hd660s, if possible also the andro2020 why not, depending on the impedance
the underlying question would be if desktop dac/amp or even only amp would sound better than small portable daps
Hi there! You raise some interesting questions... If you are using Tidal on your DAP bit perfect from the app, which I think is the case, you might get worse sound using the TA 22 via Bluetooth, depending on the CODEC you connect it with. On the other hand, if you connect your DAP via USB cable to the TA 22, I think you will get better sound and with that wonderful tube flavor.Hi!
Can you tell me which cable you are using to connect your AK to the TA-22 ?my stellia,or your and my audeze LCD2CB is bassy,so better works with non bass gain tubes ,i think. JJ,TJ Full Music.EH electro harmonics?
so far so good. tried more tubes, compared vs my astell kern SR25ii dap. i like neutral sound. so, stellia works nice here. im return to RfT 1960 tubes, as they neutral sound and same sound as from my SR25ii. stock incredible good too, similar neutral sound like RFT , but has a bit lower highs. tungsol tubes a bit warm to me. need try bright sounding Gold lions one day i think.
I think he can't reply you. Noted that he is under banned status.Can you tell me which cable you are using to connect your AK to the TA-22 ?
Let's us know your DAP and its connections so that we can suggest the cable.Hi there, can I please get a recommendation for an optical cable to connect the TA22 to my dap ? Thank you
Fiio M11 plus. 4.4mm balanced out/line out, 3.5mm headphone out/line out/ coaxial out. Thank youLet's us know your DAP and its connections so that we can suggest the cable.
Regards!
