This little amp (MT-602) is still going pretty good today. I stepped over to the T60 Argons this time and I had to drop the volume from 1:00 ( with HiFiman HE6se V2's) down to 10:00. This unit will be a nightmare with efficient headphones, but I have some idea's for that.
But it really is a nice sounding little amp. This has got to be the bargain of the year! At least for harder to drive headphones.
That is what is so cool about the Xduoo Tube/Hybrid amps, the sound we are getting - and can get by tube rolling - is so sweet for such a small $ investment. It really is magical sounding so easily.
I am REALLY looking forward to rolling my additional tubes. Hopefully they have a lower gain/amplification factor.
Well, the Hybrid design of the TA-20/TA-30 won't provide gain variance by rolling different tubes. Swapping in 12AT7 from 12AU7 doesn't increase volume at the same dial setting, and it doesn't get any louder with a 12AX7 either.
The Hybrid design's pre-amp tube(s) as a fixed gain stage, and the SS stage is the actual gain stage.
The 12AU7 in the TA-20 for me gives the same volume as the 12AT7 and 12AX7, it is the sound characteristics that change.
It will be interesting to see if the Xduoo MT Hybrid models operate the same.
If the output is too hot for IEM's, then something like the
iFi iematch+ would be a good adapter to plug in between the headphone jack and the IEM to attenuate the output of the headphone amp. That will give you deeper clearance into the volume dial, lower noise, and tame the gain
If you are looking for a great sounding 12AU7 that doesn't break the bank, the Ei Yugoslavia tubes manufactured on Philips and Telefunken equipment under license for both sound sweet. At least these sound sweet right now on my TA-20:
4 Strong Matched NOS IC Ei Yugoslavia Long SMOOTH Gray Plate 12AU7 / ECC82 Tubes
https://www.ebay.com/itm/124890637162
And, has a single "used" tube that measures well over 100%+/100%+, see numbers written on White box + Description details:
Strong Ei Yugoslavia Long SMOOTH Gray Plate O Getter 12AU7 / ECC-82 Tube
https://www.ebay.com/itm/125087578210
And, there are other combinations and a 12AX7 listed, and if you ask desireme1979 nicely she might have a new boxed single tube available. These sellers usually have a varying stock much larger than they can keep listed at one time:
https://www.ebay.com/sch/i.html?_dmd=2&iconV2Request=true&_ssn=desireme1979&store_cat=0&store_name=michelleselectronictubesnmore&_oac=1&_nkw=ei yugoslavia
These IC Ei Yugoslavia Long SMOOTH Gray Plate 12AU7's are the most sweet sounding 12AU7 tubes I've tried - if bought/heard these first I might not have even branched out to 12AT7's soon quickly! While not as euphonic as the 12AT7/Brimar 6060/Mullard 8126/E180CC it is great sounding without any negative attributes that I have heard in the last few days. Easily a great recommendation for a first/last 12AU7, especially if you can get a discount because it is used but measuring over 100%+/100%+.
https://www.audiophonics.fr/en/preamplifier-and-volume-control/xduoo-mt-603-tube-preamplifier-12au7-p-15522.html?search_query=mt 603&fast_search=fs
Usually it takes a couple of weeks to get stuff from them, but at least the order is in
EDIT: I did get an answer from Sam at xDuoo already regarding tube compatability for the MT-603.
Quote; "Yes, you can also use other tubes 12AT7, E180CC, 12AX7, but the best result is using 12AU7,ECC82, we already adjust the sound basis on these two tubes."
That's great news, plenty of options for tube rolling!
BTW, the 12AU7 is the US designation and the ECC82 is the European name. Same tube, different "standard" name. Gotta love standards that come up with a new name to "clarify" things
The MT-603 product page doesn't mention anything about Transistor stage, so the MT-603 is all "tube" sound, so that will be fun! No interference from SS "cleaning" up the sound, it should be full euphonic with 12AU7 instead of a 12AT7 to "liven" up the sound.
Please see the Seller
desireme1979 store, she has lots of single tubes with clearly labeled measurements in the photo's - written labels on the "white box"- and in the listing detailed text description. Measurements over 100%+/100%+ are technically close to new and should sound new too.
desireme1979 is easy to message and get to know, you can let her know you are starting out and she will recommend inexpensive tubes - a good place to order any time, but especially early on when you are learning.
Lots of fun
