What kind of noise? Did you unplug your headphones from the TA-26 when using it as a Preamp? How long are your RCA cables to your AMP from the TA-26? Are those RCA cables well shielded? Is the noise a hum/or high frequency "hash" - variable not constant?
I had problems with my Topping A90 RCA output, and I had to find cables with a Quad Shield design - floating shield at destination (RCA shield), and that got rid of the noise for me.
Before that I tamed the ground loop noise by upgrading my power strips on consolodating the power to the connected chain of devices and that remove that noise source.
Later I bought a Ravpower Battery powered Pure Sine Wave power source to run my Topping A90 / D90 - and that wasn't connected in any way to the local ground - such small battery sources don't have ground connections when running disconnected from charging power - and this one has a charger that is also ungrounded. That change took away more noise and increased the black silent backgroud.
What also can help is using XLR connections, with a similarly Quad Shielded floating shield at destination (XLR cable shield), which the D90/A90 support.
IDK if getting RCA to XLR converter at the TA-26 end, and self-powered speaker / pre/integrated amp with XLR input might also help reduce the noise.
It took me a while to work all this out with my set up, so please hang in there an keep trying solutions
