Thinking about getting the MT-604, but my efficient headphone collection runs from 32 to 80 Ohms. So as with my LP (probably more so), gain will be an issue. There are several options and I was curious about some feedback:
1) My two existing amps can both operate as pre-amps, but I am not sure if that will fix the problem. Won't know until I try.
2) I can pull my SMSL SU-8 DAC out of the office and run two DAC's in my system to get the volume feature. Seems kind of redundant, but certainly the cheapest outside outside of pre-amping. And I do like this DAC.
3) Attenuation. Kind of in pre-amp territory. There are inline attenuators on Amazon.ca ($45.99 X 2 and get -15Db's). Garage1217 also sells attenuators (-20Db), but it is for after the amp. It is a 4-pin XLR headphone out? With this you only need one ($45.00US), but how would the sound be affected? Pre-amp? After amp? I have no idea.
I can get this amp in Canada for $225.00. I also found a tube supplier that sells 403b's in matched sets. He has several matched sets and can recommend two similar matching pairs and all four would be about $90.00 (thanks
@Wiljen). I like what I hear about this amp and the cost at about $300.00 - $350.00Cdn. seems like a decent risk. It is not dirt cheap, but everything costs more in Canada.
Anxious to hear feedback from owners/potential owners. To be clear my biggest issues are that my headphones are Very efficient and I am not a loud listener.
Thanks.
