ta-26 is old model. so they making new OTLmy guess is no since they have the ta-26s.
Xduoo Amplifiers
- Thread starter JoeDoe
LakeOfTheWyles
they just released an updated one, the ta-26s with a balanced 4.4 hp jack. It’s basically the same, so hopefully you’re right.ta-26 is old model. so they making new OTL
Is it worth to upgrade from my Singxer SA 1 to the TA-22 if i use a external Dac? I dosent need that on the TA-22. Or are there a equal Alternatives without a Dac?
can use ta-22 and no need additional dac or amp only xduoo mt-604Is it worth to upgrade from my Singxer SA 1 to the TA-22 if i use a external Dac? I dosent need that on the TA-22. Or are there a equal Alternatives without a Dac?
S Crowther
TA-20Is it worth to upgrade from my Singxer SA 1 to the TA-22 if i use a external Dac? I dosent need that on the TA-22. Or are there a equal Alternatives without a Dac?
old model….TA-20
Thank you is it better than the xduoo mt-604? Or is it worth to switch from the Singxer SA 1 to the TA-22 as a Balanced Amp?TA-20
ta-22 is newest,best tuned,compact size amp with dac and ,not very hot as ta-20,ta-30 amps. .always newer is better then oldtimers.Thank you is it better than the xduoo mt-604? Or is it worth to switch from the Singxer SA 1 to the TA-22 as a Balanced Amp?
TA-20 is not very hot, where did you get the idea that it's hot?ta-22 is newest,best tuned,compact size amp with dac and ,not very hot as ta-20,ta-30 amps. .always newer is better then oldtimers.
It's already clear that the newly released amp is the latest/best in the Xduoo range. But the Singxer SA1 is an excellent headphone amp which I don't know if the Xduoo can keep up with. Of course, the tubes add their own sound characteristics, but then I can also buy a tube preamp. However, if the Xduoo is technically on a par with the Singxer SA1 (which I don't think since the production costs also fall into the tube section and Dac - the Singxer SA1 is a pure headphone amplifier for the same price) then I would go for the Xduoo. An alternative would be to get a Douk Audio T8 (Balanced Tube Equilizer) and adjust the bass of my Abyss Diana V2 manually.ta-22 is newest,best tuned,compact size amp with dac and ,not very hot as ta-20,ta-30 amps. .always newer is better then oldtimers.
HiFiRobot
- Apr 1, 2013
I see 3 tubes on TA-20 Plus, or?Waiting for the TA-20PLUS to be released...
S Crowther
Until TA-20 PLUS is released the TA-20 is the best Xduoo headamp without DAC.
LakeOfTheWyles
I think it depends on what kind of sound you’re looking for as well as what headphones/iems you have. From reviews the ta-22 seems to be silent enough for iem’s and puts out 3000mW. The ta-20 puts out 2000 mW. I have not heard the ta-20 so I’m not sure about its noise floor. The Schiit Lyr+ pushes 6000mW, similar to the Sa-1. It’s seems to be having some QC issues, and Josh Valour thought the sound quality of the lyr+ and ta-22 were comparable.It's already clear that the newly released amp is the latest/best in the Xduoo range. But the Singxer SA1 is an excellent headphone amp which I don't know if the Xduoo can keep up with. Of course, the tubes add their own sound characteristics, but then I can also buy a tube preamp. However, if the Xduoo is technically on a par with the Singxer SA1 (which I don't think since the production costs also fall into the tube section and Dac - the Singxer SA1 is a pure headphone amplifier for the same price) then I would go for the Xduoo. An alternative would be to get a Douk Audio T8 (Balanced Tube Equilizer) and adjust the bass of my Abyss Diana V2 manually.
I’ve had the xduoo ta-10r, and the mt-602 in the past. I have the Sa-1. The 10r definitely sounded better to the 602, especially with a better tube. The Sa-1 has more power, and better detail retrieval than both. None of the tube amps we’re talking about are very tubey, but they do add some nice flavor. I do like the like the low end of the 10r compared to the Sa-1. It’s not as quick as the sa-1, but with the right tube it’s more immersive to me. If you’ll just be using balanced connections, the jot2 is an option. I find it punchier, and more fun. Similar detail retrieval, and more power. It has a deeper stage, while the sa-1 is wider.
So none of these amps are a direct upgrade or replacement for the Sa-1. Definitely more complimentary. I personally have had good luck with xduoo. Might be worth waiting for the ta-20 plus, or if you can get a deal on the ta-30. I’ve seen it marked down for less than the sa-1 lately. Maybe get the mt-602 to see if you like the sound (preferably returnable) before dropping more money.
Total: 7 (members: 0, guests: 7)
