Oh I see. No, you would just get the amp, charger, and mini-to-mini cable. How much quality you lose through the HP-out? Not much, if at all, with an amp as good as the Minibox-ES. If anything, it will make your headphones tighter, smoother, cleaner, and clearer in sound plus open up the soundstage. You will also get mildly longer battery life from your Zune since it will be seeing a high impedance load and the minibox does all the amping work instead of the Zune's built-in amp.
Would AD700 benefit from iBasso D4 Mamba?
- Thread starter sennheiserhd485
