kingpage
- Apr 26, 2010
Honestly, if you've never heard the headphone in question, don't speak as if you have. It's that simple.
Where did you get the idea I "implied" I have heard them?
Please, I may argue everybody's judgement on the requirment of amp is a very subjective matter. If I owned HD650 and said they sound good enough with E5, it wouldn't be wrong.
What about recommending headphones you "heard (from reviews/friends)"?
Nothing wrong with that, imo.
I don't have any authority on that subject. From what I have read from many reviewers, those two are regarded highly and have been compared to a number of other top-tier universial IEMs. In terms of which one is better, it's probably down to preference.
Yeah, this guy has a problem with every single head-fier who has said something positive about a product or company that they had never experienced first-hand; he's calling those comments blind hypes. I trust people like Joker (and many other veteran head-fiers) enough to recommend ksc75 to others (fellow head-fier or friends or family) if they needed some quality headphones for under $20. But that's blind hype too unfortunately by the definition of a well-spoken head-fier Blue Boat.
But it's always good to put a disclaimer: I personally haven't heard these, so maybe you should check up on appreciation/hater threads.
And then offer other options.
Blind hype is this, you twit.
HEADPHONE A IS BETTER THAN HEADPHONE B MANY TIMES ITS PRICE.
Well, companies like Brainwavz and Fischer Audio make headphones that rival ones that cost over $300 or $400 and priced them at $140-170.
Headphones are about a year or two behind IEMs in terms of the cheaper headphones competing with ones that are many times their price. It all began with RE0 and then DBA-02.
From my experience, those two compare to a number of other top-tier universial IEMs. In terms of which one is better, it's probably down to preference.
John /img/forum/go_quote.gif
Well, imo companies like Brainwavz and Fischer Audio make headphones that rival ones that cost over $300 or $400 and priced them at $140-170.
Headphones are about a year or two behind IEMs in terms of the cheaper headphones competing with ones that are many times their price. It all began with RE0 and then DBA-02, from what I've read.
In terms of which one is better, it's probably down to preference. I'd go for the RE0 purely based on reviews.
You just contradicted with your principle here.
Please don't change anything when you are using direct quotes with my username. It is called dishonesty in academia, and it's not far from it in online forums. You may put the sentences in your own quotes as examples for illustration.
umadbro? Name calling is for kids.
I didn't say better. Strawman? These are your words not mine.
How?
I was half trolling/recommending another option.
Originally Posted by loliwin /img/forum/go_quote.gif
buy Skullcandy Skullcrushers. I heard they have subs in those.
Dude, if you dont know what you're talking about please do not post. I have the skullcandy skullcrushers. They have no bass, just vibrations, and are all plastic. ****tiest headphones I've ever had.
