- Mar 5, 2012
I've never really used the D/A mode on my WA7. I just recently started to use it with my new Sceptre S8's + Temblor T10.
The T10 is the sub controller, has balanced inputs. I bought a balanced DAC but it won't be here for a few weeks.
The T10 also has RCA unbalanced inputs that I'm using from the WA7. I get a low analogue noise hum. Is this normal? I assume it is because it's not balanced, and that's the main reason to use balanced inputs. I just want a second opinion.
You might have a ground-loop with the Temblor T10. Try lifting the ground on it. Also, be sure to use high quality RCA cables less than 3m runs.
There are many dacs that would be considered an upgrade. Considering the WA7 doesn't do DSD, a lot of DSD-capable dacs would be considered an "upgrade" in my opinion.
If you're interested in a DSD dac, ted_b has a dac database up on Google docs that he's shared a link to: DSD DAC Database
We don't put non-matured features on our products. That is why we don't need to update our products every two years to keep up with trends. Disposable electronics are bad for the consumer and bad for the environment.
