abvolt
chry5alis said:
Great post glad to hear your enjoying the Woo there awesome amps no doubt..
chry5alis said:
Sounds like someone has been bitten by the audiophile bug. Congrats, happy listening.
That sounds cool Jeb I've also been thinking of getting a bottlehead crack to build love to tinker with electronic gear, let us know how your new amp sounds..
Which amp are you doing ? i'm thinking of the OTL + speedball
Just got my WA7 and it pairs phenomenally with my T1s. However, I don't have the anti-slip pads. Any suggestions for something that might work while remaining fairly invisible or where I can get the pads?
I use Glue Dots on mine , a single dot cut into quarters gives four tiny corners
Holds well for dusting etc but still easy to lift for tube rolling
Good idea, thanks! I take it they're not too tacky? I'd be worried about knocking the tubes around picking the glass up.
Remember to buy the non permanent version or you will be stuck
You can reduce the tack just by pressing with a finger a couple of times
