groovyd
- Jun 29, 2012
i am working on a 3d printed shim at the moment to fill the gap between the tube collar and glass bore. stay tuned.
I lost two of the rubber stopper of my WA7. Any idea where could I get them?
Did you ask Woo Audio ?
I received a set of clear instead of black ones when I first got my WA7. I emailed Mike and was sent a set the next day. I'd contact support or Mike and I'm sure they'll be able to take care of you.
Hi,
I'm looking for an upgrade for my current headphones. My cans are K701 and HD600, my amp is wa7 with upgrade tubes + wa7tp with Mullard M8136. I prefer K701 more than HD600 with wa7.
My interesting list are LCD-X, LCD3 and th900. I like to inquiry which one would be pair with wa7 best.
Thank you!
I have the LCD3 and TH900, both sound spectacular with the WA7+WA7tp. I'd go with the one that matches up with how you'll be using the headphones and any sound preferences. The WA7+WA7tp works well with everything I've thrown at it.
Would you please compare the sound stage and sound signature between TH900 and LCD3? I like the wide sound, a little warm but not too much bass. Like K701 compare to HD600.
they all pretty easy enough to drive and work fine with the WA7. The LCD-3 would be the hardest to drive out of that line-up, but I've heard of people using it with the WA7 no problem.
In terms of sound sig, TH-900 would be the most v-shaped version of neutral out of all of them. lcd-3 is mid-centric dark version of neutral. lcd-x is the most neutral (according to my personal tastes), but still subtly slightly darker (compared to the HD800). I think they all have more bass than the other flagships, would be more along the lines of a HD650 or HE-400 if trying to do a mid-fi sound sig comparison (imo). This is driven out of transparent solid-state amplifiers with minimal additional coloring added.
My neutral would be defined as the K712 65th annies (so imagine the K701 with ~3db bass boost - may be similar to your k701+warm tube amp, i've never tried that specific combo). The K701 would be considered bright in my mind. The K701 and HD600, those I feel are more similar than different among the mid-fis. Similar flat analytical type tuning compared to some of the other options. Not warm at all IMO and a bit lacking in bass for my tastes. If pairing a 'bright' or 'neutral' pair of headphones like the k701/hd600 with the warm tube amp like the wa7, you can get a sense of warmth with your sound signature though, but that's primarily from the amplifier. The k701/hd800 would scale up into something like the K812 or HD800 respectively.
Widest sound stage out of all flagships would be the HD800, but they lean towards the brighter side of neutral. The TH900 has a wide sound stage for a closed headphone (so many people comment positively on that aspect), but recessed mid-range compared to other options. Warmest sound from my experience would be the Oppo PM-1s, but they have a average sound stage for a flagship.
Honestly, I think the best TOTL for you would be the AKG K812 pro as they share a similar house sound to the K701 which are your preferred, have a very wide sound stage, and are extremely easy to drive so the kinda low power output of the WA7 will not be a problem. Can see the AKG K812 pairing very well with a warm amplifier. The options you have listed might get too warm, I personally would just solid state with them.
For the options you have listed, if I were to apply a mid-fi sound signature that's closest to them, I would estimate something like TH900>Ultrasone Pro 900, LCD-3>Sony MDR-1A, LCD-X>HE-400. The hi-fi options have more refined overall sound signatures and better resolving capabilities, but just a parallel sense of their sound imo.
I would recommend demoing some TOTL to get a sense of your preferences exactly, and I might be able to offer better advice.
My neutral would be defined as the K712 65th annies (so imagine the K701 with ~3db bass boost - may be similar to your k701+warm tube amp, i've never tried that specific combo). The K701 would be considered bright in my mind. The K701 and HD600, those I feel are more similar than different among the mid-fis. Similar flat analytical type tuning compared to some of the other options. Not warm at all IMO and a bit lacking in bass for my tastes. If pairing a 'bright' or 'neutral' pair of headphones like the k701/hd600 with the warm tube amp like the wa7, you can get a sense of warmth with your sound signature though, but that's primarily from the amplifier. The k701/hd600 would scale up into something like the K812 or HD800 respectively.
Honestly, I think the best TOTL for you would be the AKG K812 pro as they share a similar house sound to the K701 which are your preferred, have a very wide sound stage, and are extremely easy to drive so the kinda low power output of the WA7 will not be a problem. Can see the AKG K812 pairing very well with a warm amplifier. The options you have listed might get too warm, I personally would just go solid state with them.
Not sure if I should start a new thread or not. Let me know if I should.
I recently picked up on a WA7 and I do like it quite a bit. However I have experienced an issue. Wondering if anyone else has had this happen. I have it sitting in front of a Mac Mini and I get some interference I am assuming from the Mac. Perhaps RFI or EMI. I pick up noise as well as some harshness in the upper mids.
I just wanted to see what others have found in regard to how close they have the WA7 to a computer.
Thanks
