When looking into buying the WA8 this was the one main thing that came up as a potential problem. Mine is working fine and is almost 2 years old. I would take the issue to Woo directly, you'll likely have to send it in for repair.
Woo Audio WA8 Review - Head-Fi TV
- Thread starter jude
- Tags
- woo audio woo audio wa8
I have not contacted them yet, but I think you're right in that I'll have to send it in...
Which one did you get?Thanks for the answers. I am looking for transpotable DAC/AMP for using with ZMF Verite and my choice is between Hugo2 or WA8.
- Oct 24, 2006
I too have issues with the dac, tested them on windows 10 and mac os, but no dice. Unfortunately i’m overseas and shipping is horrible for me. Please share if it gets resolved. Good luck!
Is anyone here with experience to drive ZMF headphones, OR can compare the WA8 with the performance of the Hugo 2 with dynamic headphones?
Thanks in advance
Thanks in advance
Hi! I've tried the HD800S with the Hugo 2, Hugo TT and I own the WA8.Is anyone here with experience to drive ZMF headphones, OR can compare the WA8 with the performance of the Hugo 2 with dynamic headphones?
Thanks in advance
Simply put, the Hugo and WA8 don't compare. I liked nothing about the Hugo 2. Not the sound, not the look, not the controls. I think it's overhyped.
And this is not Hugo bashing - I Love the Hugo TT. I just think the Hugo is not up to the price and hype, whereas the WA8 was a total and very good surprise.
Having said that, there's quite a difference in sound between solid state and tube so make sure you like the general "styling" of the sound.
And If you do prefer a Chord, make sure you compare the Hugo 2 with some of their higher tier offerings only to have as a reference.
Hope this helps.
Pictograms
Probably not that helpful, but I used to think the Cayin HA-1A was my favourite amp for the Eikon but I like the WA8 more in everyway. The only issue I could see is power, but I have never needed to go above 3 on the WA8 with dynamics.Is anyone here with experience to drive ZMF headphones, OR can compare the WA8 with the performance of the Hugo 2 with dynamic headphones?
Thanks in advance
I don’t have the Eikon anymore but I have the TH900 and the Cascades if you have experience with them.
Ive never owned the Hugo but seems to me of detail is your main goal that might be a better bet.
It's the perfect partner for FW10000, lol
Thanks in advance
Hope this helps.
I just posted this in the Stellia thread, though I think it is relevant to the above.
Spent some time this afternoon testing the Stellia between the Hugo 2, Woo Audio WA8 and iFi Micro BL. In short, they were all amazing but my take is that they perform in line with their respective price point. In Australia that is $3800, $2800 and $800 respectively. Having tested most other portable/transportable options at these price points, I’d say that these 3 are the only real contenders.
- Hugo remains a standout to me. Clean, clear dynamic sound with filters to roll off the slightest of peaks as needed. Easily the most dynamic here and appropriate for office use for me.
- WA8 was a surprise and fits perfectly in the middle. The warmth of the tubes and slightly less capable DAC lose a little detail to the Hugo. I actually think this would be a really nice evening option for hotel stays for work and so forth.
- iFi Micro BL represents incredible value for money, as does the HipDAC I owned prior. Whatever issue I had last time I tested this was gone. Loads of power, dynamic punchy sound. Bass + bloats bass a bit more than I’d like, though it is track dependent. Generally this device just makes you smile and it’s one of the most fun devices here. The sound however is a little more commercial than the others, which I think would appeal to the widest audience.
All fantastic devices, but my overall vote goes to the Hugo 2.
jamington2004
- Feb 23, 2015
Just picked up one of these bad boys for my Tia Fourte. Never tried tubes so was initially taken a back by the different presentation, finding it a bit too warm / bassy / wooly after a few tracks especially on bass heavy music. 3 tube mode was a definite no no (I prefer a flat response usually). Switching back to Qudelix 5k seemed like a breath of fresh air - so light and airy by comparison.
Then I had a proper listening session for an hour last night (2 tubes) and especially on stuff like Radiohead / Placebo / The Yeah Yeah Yeahs I realised what all the tube fuss was about Then back to some Psy trance and hip hop now I was used the sound a bit and wow wow wow
Annoying about the pop when switching off - is there a fix for that? I bought used btw
Also is it ok to lock back in case while hot? Annoying to have to leave it out before putting away otherwise
Thanks
Thanks
- Aug 15, 2011
Welcome to the world of tubes. It’s definitely a taste once acquired, is addictive (esp when tube rolling). Not all tube amps sound so “ tubey” but the WA8 definitely leans toward the more “tubey” side.
The pop is normal on the WA8 unfortunately, esp when switching between DSD & FLAC too. Also don’t change between two tube & three tube mode without switching off the WA8. Whilst I’ve not had any problems accidentally doing so, the recommended procedure is to switch off the WA8, then switching.
jamington2004
- Feb 23, 2015
Looking forward to my next session already Although I also thoroughly enjoyed a quick walk before work with the Qudelix - it’s really impressive for something so small!
Any thoughts on locking it in the Peli case when hot?
Also I assume the batter is super clever and I can do what I want with charging / letting it run out completely / playing while charging etc?
And is the batter totally full as soon as final light is red? It seemed super quick to get to full charge from dead??
Thanks to anyone who knows
jamington2004
- Feb 23, 2015
Just read a manual I found online - it says to always disconnect the charger when the battery is fully charged.
Not very convenient meaning you can’t leave to charge overnight! And not very clever compared the Hugo 2 charging where you could do what you wanted without being bad for the battery
jamington2004
- Feb 23, 2015
Spoke to Woo and it’s not a problem to leave plugged in once charged as it disconnects the power when the light on the brick goes green.
In case it’s of interest for others
stringgz301
- Sep 11, 2009
I picked up a WA8 a couple weeks ago to use at the office. My initial impressions are very positive. I'm mainly listening through my UE 18+ CSX iem's. With the stock tubes (the delivered driver tube in mine is a Thomson) I find the imaging is very good, detail retrieval strong, and overall quite pleasant. I do find that vocals in the middle of the soundstage have a slight veil, vs ones that are to the side. I also got the Sylvania 6BF7 upgrade driver tube and enjoy this configuration a bit better, with vocals really blooming, the bass being a bit deeper, and that center veil disappearing. Overall I find the soundstage to be quite wide but not very deep which can sometimes lead to some congestion in the middle of the soundstage with complex multi-instrument music. It is really well suited to acoustic, bluegrass, and jazz.
I also tried the WA8 with my Audeze LCD2's. I usually use these in my main rig (Benchmark 2 Dac -> Leben CS300 -> LCD2) where the LCD2 + Leben combo is magic, especially with the right tubes. With the WA8 I definitely enjoyed the LCD2's, although the soundstage isn't as big as with the Leben and overall the control and impact, especially in the bass, isn't at the same level. The WA8 has no problem driving the LCD2's, with a comfortable volume around 5.
Overall I think the WA8 is a great option for people who need some portability and a smaller footprint. The Sylvania driver is definitely worth it if you vocals are at the top of your list.
