Silent One
What silence said... then nothing.
- Aug 9, 2010
I'm selling a EML 5U4G if anyone is interested. I'll cut you a little Woo WA6(SE) discount if anyone wants it
I've had my WA6 for about two weeks. I bought it used with the stock tube set.
My listening reference has been the Burson 160D to this point-- I only own HD650s and UE In-Ear Reference Monitors (saving for the LCD2 at the moment) and I will continue using the DA side of the Burson for the foreseeable future-- as I haven't run across a DAC that can do what the Burson does.
On that note (pun intended) the Burson ate up the WA6 with standard tubes. The Burson had definition in the bass which was sorely lacking from the WA6 and the highs were much clearer under the Burson. I was also picking up some sibilance on the standard tube. The Burson really excels at keeping all of the parts of the sound in place. It has a way of making the total sound cohere better than my other D/A / Amp options. I had a Sophia Princess tube on order, and it arrived a day or two after the WA6. I also ordered on eBay a '58 Mullard GZ34 (NOS).
Changing out to the Princess made a world of difference. I still preferred the Burson to the WA6, but at quieter volumes the Princess held its own. Under the Princess the upper frequencies grew clarity and the sibilance disappeared. The bass extended a bit and the bottom also found a bit of definition which was lacking.
Last week the '58 GZ34 arrived. It lacks the light show of the Princess. And on that note alone-- the Princess is probably more fun to listen with. But the muster is in the sound-- and here the GZ34 upped the ante significantly-- so much so-- that in just pluggin in the rectifier tube without much warm-up at all, I really had a hard time hearing much difference at all from the Burson. The sound is practically identical-- Hot swapping-- It might be a shade warmer, but honestly, I couldn't make out any significant difference. Which makes me wonder where things will stand once the GZ tube comes on a bit.
I have 1 more rectifier on the way-- another GZ varietal-- this from Holland, and a bit more pricey-- time will tell. On order due Monday-- the first change in the power tubes-- the 6GL7/6EM7. Woo claims it to be the best power tubes they know of-- can't wait to see what change comes with them.
How would you compare the soundstage between the GZ34 and the Sophia? Thanks for the post btw (great pics).
1) Mullard GZ-34 (1958)
My sole pair of hi-fi headphones-- the Sennheiser 650. I'm plotting a purchase of LCD-2s but unfortunately Nikon derailed my plans when they released the new D800 this week. Camera (work stuff) takes priority over play.
Woo sent me Amperex 6GL7s with the adapter bases. I just couldn't get them to work for me.
I have on order from Woo the 6SN7GTs and adapter bases. I'm hearing good things. Currently I have stock RCA 6DE7s.
Did you get your CV593 off of eBay? There's a guy with a bunch of NOS '67s for sale at $100 each. You are in for something REALLY special. So far, I think it's a dream tube. I'll post my thoughts here after they burn in, but I spent the entire night going back through my favorite tracks, which should tell you something.
I forgot how good the GZ34 actually sounds. Man that Mullard company knows a thing or two about making tubes..
I wasn't crazy about the stock 6SN7s tubes that came with the adaptors from Woo.. I think they were RCAs, I actually preferred the stock setup, but if you can get your hands on some new old stock 6SN7GTs its supposed to be great (I searched a bit when I had my WA6 and they are pretty tough to find).
