ShaolinGrump
UpstairsDownstairs rack complete. Umbilical bend was tricky. Had to size the lower shelf height to within ~5mm of the transformer lid.
![IMG_0626.jpeg IMG_0626.jpeg](https://cdn.head-fi.org/a/12391250.jpeg)
![IMG_0627.jpeg IMG_0627.jpeg](https://cdn.head-fi.org/a/12391248.jpeg)
WA6SE delivers more power than WA6; this is true with both Gen1 and Gen2. For tube rolling, WA6 (not SE) Gen1 offers the most opportunity. The rectifier tube, 6922 via 6922 => 6DE7 adapter, 6SN7 via 6SN7 => 6DE7 adapter, 12AT7 / 12AU7 / 12AX7 via 12AU7 => 6DE7 adapter.I'm having a hard time coming up with an answer to this. Wa6 vs Wa6 SE? I've found some discussion saying they liked the SE much better, but not much more direct comparison otherwise
I'm still teetering on waiting for a cheap Wa6 gen 1 to pop up or snagging a Wa6 SE gen 1 which comes with a bunch of tubes
But how do they compare sound wise? I'm aware you have more tube rolling opportunities with the Wa6 but I'm assuming with more power you're going to get a potentially more detailed and harder hitting amp with the se compared to a softer lower power Wa6.WA6SE delivers more power than WA6; this is true with both Gen1 and Gen2. For tube rolling, WA6 (not SE) Gen1 offers the most opportunity. The rectifier tube, 6922 via 6922 => 6DE7 adapter, 6SN7 via 6SN7 => 6DE7 adapter, 12AT7 / 12AU7 / 12AX7 via 12AU7 => 6DE7 adapter.
.... only if the same tubes are used in WA6 and WA6SE ....But how do they compare sound wise? I'm aware you have more tube rolling opportunities with the Wa6 but I'm assuming with more power you're going to get a potentially more detailed and harder hitting amp with the se compared to a softer lower power Wa6.
Right, so if you're rolling the same tubes or equivalents for example what does the SE do better as a base than the 6. If tubes were the only reason for overall sound we wouldn't need more expensive amps.... only if the same tubes are used in WA6 and WA6SE ....
**** provide more power. This may be the determining factor if you are thinking to use 'hard to drive' headphones.Right, so if you're rolling the same tubes or equivalents for example what does the SE do better as a base than the 6.**** If tubes were the only reason for overall sound we wouldn't need more expensive amps![]()
I have a gen 2 and it’s a really great amp. To my taste it prefers headphones with at least 80 ohms impedance, but it’s going to have some magic with the BrimarManaged to find a seller for a Gen 1 Wa6 SE so have that coming in. He's including a Brimar and a couple different audio tubes for me to try out. Should be arriving tomorrow!
My main HP is the 660s2 300ohm which I love. I might try out the 250ohm 1990 as well. Will be adding an HD800 probably by the end of the year and some ZMF headphones after that! I'm pretty happy with my Bifrost 2/64, maybe grab an Yggy somedayI have a gen 2 and it’s a really great amp. To my taste it prefers headphones with at least 80 ohms impedance, but it’s going to have some magic with the Brimar
I kind of followed a similar path to you. I had a Lyr3 + PSvane CV181 TII, upgraded my DAC to a Bifrost 2, upgraded my amp to a WA6 SE, upgraded my amp again to a Folkvangr, Upgraded my DAC to a Yggdrasil, bought another SS amp. IMHO the upgrade from the Lyr to the WA6SE will be clearly audible.My main HP is the 660s2 300ohm which I love. I might try out the 250ohm 1990 as well. Will be adding an HD800 probably by the end of the year and some ZMF headphones after that! I'm pretty happy with my Bifrost 2/64, maybe grab an Yggy someday
Yea that's pretty much the path I'm taking lol. Though instead of a Folkvangr I'll likely end up at higher end Cayin, Woo or Feliks tube amp. I am expecting my Lyr+ to be for sale by tomorrow nightI kind of followed a similar path to you. I had a Lyr3 + PSvane CV181 TII, upgraded my DAC to a Bifrost 2, upgraded my amp to a WA6 SE, upgraded my amp again to a Folkvangr, Upgraded my DAC to a Yggdrasil, bought another SS amp. IMHO the upgrade from the Lyr to the WA6SE will be clearly audible.
I have to admit, I thought a lot about getting a Cayin. In the end I went a different way but the Cayin tube amps are no joke. I also thought about going upscale with Woo, but the step up in price to a WA5 LE was further than I was willing to go. I also thought long and hard about getting a WA2, but I decided that’s more of a sidegrade than an upgrade. In the end my love for creative engineering demanded the Folkvangr. It is a sonic step up from the WA6-SE (tighter bass, more detail, lower noise floor) but mostly it’s just more flexible on what headphones work well with it. For some track and headphone combos I still prefer the WA6-SE. Long story short, I figure a significant tube amp upgrade from the WA6-SE / Folkvangr price point is likely to cost a lot more than I want to spend for now. I did add a nice SS amp which allows me to choose between the thicker, creamier sound of a tube amp and more resolving tighter sound of a SS amp.Yea that's pretty much the path I'm taking lol. Though instead of a Folkvangr I'll likely end up at higher end Cayin, Woo or Feliks tube amp. I am expecting my Lyr+ to be for sale by tomorrow night
What'd you think about the upgrade from Bifrost 2 to Yggy?
