Hi Robert can you check PM if you have a spare minute? AppreciatedYeah definitely. IMHO proformance is the result of all of the small details.
Of course. PM repliedHi Robert can you check PM if you have a spare minute? Appreciated
ColSaulTigh and David222, check this out:
When I was seven / eight…Love it. Looks fantastic! The Testors paint makes me wonder if you have a model airplane collection?
I have the WA6 1st Gen….and a number of 300 ohm ZMFs (Aeolus through Eikon). Set the impedance switch on the back to high; you will be fine. While the ZMFs have high nominal impedance, they are rather efficient.Would the WA6 2nd Gen have enough power to listen to ZMF Verite Open or would i need to upgrade later on to WA6-SE? Would i have to max out the volume or would that not even be enough. Curious what you all think
Thank you so much Jonathan was abut worried there for a secondI have the WA6 1st Gen….and a number of 300 ohm ZMFs (Aeolus through Eikon). Set the impedance switch on the back to high; you will be fine. While the ZMFs have high nominal impedance, they are rather efficient
The WA6-SE Gen 2 has separate High Z and Low Z outputs. Should have plenty of juice to drive them, just use the High output.I have the WA6 1st Gen….and a number of 300 ohm ZMFs (Aeolus through Eikon). Set the impedance switch on the back to high; you will be fine. While the ZMFs have high nominal impedance, they are rather efficient.
USAF "Mighty" 596 w/ Woo Audio Adapter- saw you own this one. What's your thoughts on this tube? Would love to snag it at some pointThe WA6-SE Gen 2 has separate High Z and Low Z outputs. Should have plenty of juice to drive them, just use the High output.
Here is a picture of my WA6 (‘Sixilla’)…USAF "Mighty" 596 w/ Woo Audio Adapter- saw you own this one. What's your thoughts on this tube? Would love to snag it at some point
Its just so gorgeous i cant get over. Thanks for sharing like always and being so kindHere is a picture of my WA6 (‘Sixilla’)… with the USAF, you should get the Woo 596 => 5U4 adapter ($150) - exquisitely made. The 596 is a great choice - a good complement to my usual Brimar CV1863.
Actually, I own two:USAF "Mighty" 596 w/ Woo Audio Adapter- saw you own this one. What's your thoughts on this tube? Would love to snag it at some point
I was literally just listening to first gen WA6 with Verite Open 2 minutes ago. Plenty of power and with the right tubes sounds amazing!Thank you so much Jonathan was abut worried there for a second
