My WA6 2nd Gen is up for sale. Please buy it so I can upgrade to a WA2
https://www.head-fi.org/classifieds/woo-audio-wa6-2nd-gen.22537/
Oh yes, the Brimar sounds great, but is a nuclear reactor in that it runs very hot!@ColSaulTigh My amp is a first gen and uses 6EM7(which I understand to be the same tubes just 6 volts vs 13 volts), but to me the EM7's are quite high gain, and sound bad with most rectifiers. I get the most enjoyment from EM7's when I use the CV717 rectifier. I see you have a Brimar 5Z4GY in your sig, have you tried that rectifier with the 13EM7's yet? I'd be curious what your impressions of that pairing are. Enjoy the music!!
For <= $2000, I think that you have hit the bullseye for an R2R ladder DAC with Pontus II. [Edit: once you go R2R ladder DAC, you don’t go back…]WOO CREW!!! I need your input!
My WA6-SE 2nd Gen - Silver needs a DAC!
I'm leaving towards R2R Ladder DAC since I don't have one yet. Silver would be nice but not necessary. Budget should be within reason (let's say under $2k, unless you have a compelling reason to go over that budget point). I'm thinking Denafrips Pontuss II or similar.
Aaaaaand......go!!!
That's what my research has been pointing to, but I wanted to see if there way anyone with differing views.For <= $2000, I think that you have hit the bullseye for an R2R ladder DAC with Pontus II.
If you like a sweet sound, I’d consider the MHDT Orchid as well.That's what my research has been pointing to, but I wanted to see if there way anyone with differing views.
Now the hunt begins
I didn't hear it myself, but I would seriously consider the Holo Audio Spring.That's what my research has been pointing to, but I wanted to see if there way anyone with differing views.
Now the hunt begins
Well the Silver Wooriors are getting their first R2R DAC - a Musician Pegasus!WOO CREW!!! I need your input!
Aaaaaand......go!!!
Failed surgery to extract this little devil.
It shattered into six pieces and one of them is still inside the amplifier and I can hear it.
I hope it doesn't melt inside and cause the entire amp to malfunction.
So is this little devil going to make me spend $200 for a new one?
Yes. .but leaving that post in there does prevent you from using other tubes. A small screw turned in just enough for the threads to grab and pull it up should do the trick. A shattered post is indicative of some other form of damage (heat or stress, usually). While the bulb should function normally, I wouldn't risk it over $175 - $200. But that's my opinion.I had the alignment pin (that’s all it’s for) break off one of my rectifiers. It doesn’t conduct electricity so it can’t short anything in the amp. the hole doesn’t cause any problem. Mine was in one piece so I was able match it back to the tube and mark the alignment with white tape and still use the tube. Proper alignment of the tube pins is CRITICAL.
