If the tubes damage the unit and you got the tubes from an external source then I don’t think Woo should be held responsible. But I’m not sure if a failure due to a bad tube is distinguishable from other failures.
Woo Audio WA6 + WA6SE: Tubes, Comments, Pictures, and Advice
- Thread starter Ahzari
Law87
- Feb 10, 2014
Rocking westinghouse 6EW7 with Mullard F31 GZ34...a lot better than 5z4G
What kind of changes do you see by changing the rectifier?
Law87
- Feb 10, 2014
I have the sophia as stock with 6FD7...the brimar 5z4 more bass, slightly smaller soundstage but the mullard GZ34 add a bit more punch than the brimar 5z4, its not obnoxious bass, its very satisfying punch, this is coming from a guy who doesnt like bass, the soundstage is probaly as wide as the sophia, I have a 1939 RCA 5u4g coming in.
There is a slight change in mid between changing the power tube...with Sylvia the mid are more upfront, the Westinghouse give a recessed mid, with wider separation in soundstage (or may be a perception since the mid is recessed) but it blends very well, I like it with my HD820. the Sylvania 6EW7 is really good with my Beyer T1 (1st gen).
DMR14
- May 1, 2015
Very cool. Millard GZ34 is one of my top rectifier choices for WA6. Hope you enjoy RCA 5U4G as well. I have only listened with RCA 5U4GB version but they do sound good with various driver tubes that I have. If you can find 596, that is also very good especially with 6FD7 at least for my ears.I have the sophia as stock with 6FD7...the brimar 5z4 more bass, slightly smaller soundstage but the mullard GZ34 add a bit more punch than the brimar 5z4, its not obnoxious bass, its very satisfying punch, this is coming from a guy who doesnt like bass, the soundstage is probaly as wide as the sophia, I have a 1939 RCA 5u4g coming in.
Law87
- Feb 10, 2014
not worth the price...
DavidRoss007
- Feb 8, 2017
I have had my wa6 2nd Gen for over a year now and would like to try some tube rolling but not sure where to start. I upgraded to the SP and 13EM7 with adapters when I bought it but would like to fix the following issues
The top end can be a but hard sometimes, especially with loud vocals or when the music get complicated
Although the bass is very detailed I would like a little bit more depth/presence.
I'm using a pair of AKG Q701 with the bass mod which I know aren't known for forward bass but I love these headphones so I would rather keep them.
Thanks for reading
Thanks for reading
cebuboy
- Jul 20, 2012
Thanks for reading
How about trying some RCA 13EM7s? In the 1st gen WA6SE, the RCA 6EM7s sounds softer up top compared to the GE and Sylvanias.
DavidRoss007
- Feb 8, 2017
I appreciate the reply, I will definitely look into them. Any companies to buy from that you would recommend?
Thanks
Law87
- Feb 10, 2014
Thanks
you own a WA6 not WA6SE....confusing naming convention but thats a regular WA6... WA6SE first gen does not support 13DE7
DavidRoss007
- Feb 8, 2017
I never said I own a WA6SE, I have a WA6 2nd generation. Does that mean your recommendation would not work on my amp?
Law87
- Feb 10, 2014
read that last post wrong, I thought he was asking you to try with WA6SE...I dont have regular version.
nerone
- Feb 10, 2014
As far as I know, all tubes that work for the WA6SE work on the WA6.
The difference between 1st and 2nd generation is that the 1st generation uses 6volts vacuum tubes while 2nd gen uses 13volt ones.
If you take a look at the manual in woo’s page you’ll be able to see all suportes tubes.
1st & 2nd Gen WA6SE are not compatible with 6 or 12SN7 driver/power tubes. Only the 1st & 2nd Gen WA6 are.As far as I know, all tubes that work for the WA6SE work on the WA6.
nerone
- Feb 10, 2014
Sure, but what I said is that WA6SE tubes work on the WA6, not the other way around.1st & 2nd Gen WA6SE are not compatible with 6 or 12SN7 driver/power tubes. Only the 1st & 2nd Gen WA6 are.
