Woo Hoo!!! I had previously determined, much to my chagrin, that high gain drivers were picking up computer noise via usb. You could hear the HDD spool, etc. Also discoverd a very minor ground leak I could not work around. It only made sense to electrically isolate the computer to fix the issues. Toslink to the rescue seemed prudent. Finally got over to Frys (an electronics store) today and procured both a toslink capable sound card for pass through and cable to achieve. Installed card, drivers, adjusted to highest sample rate the Bifrost will take...and WoW! There is great improvement in the music compared to the usb. What a huge improvement in SQ! Woo Hoo!
I guess USB was not passing everything to the DAC. When I upgraded to a DAC there was a meaningful increase in SQ. Going to the toslink is a significantly greater increase in SQ.
Oh, I digressed with my excitement over the serendipitous SQ benefits. The toslink isolated the computer and the anticipated outcome was in fact realized. The high gain drivers are, for all intents and purposes, silent! High gain valves providing additional headroom are making an impact too.
The Tube du Jour is a zero hour Philips 5U4GB - yes, the music is fantastic, but how much can be attributed to the new tube is unknown!! The optical connection and high gain drivers have made a radical shift to the baseline. Ha Ha. Guess I will have to roll in my current fav, Mullard gz32 and go for a sonic trip.
The manner in which the WA6SE continues to scale is amazing...
Hey, I recently have been bouncing back and forth doing a similar thing with my Bifrost Multibit and Woo WA6-SE. First a question, which sound card did you buy and which OS are you using?
I've got a Mac Pro and went back and forth with the onboard optical out, but it's apparently limited at 96K. Overtime I was able to get the USB working better but also huge noise problems.
What I've discovered is that the origin of the problem in sound quality is two-fold, first the ground loop, it's terrible. But be aware that with an RCA interconnect connecting the ground between the computer, the DAC and the amp, nothing is isolated. So, secondary inputs on all of the above will just make it worse.
The second part of the problem, and at this point I think the biggest actual impact, is jitter. I used to be insanely skeptical of jitter, but started reading up on it's impact more on the signal. Basically it blurs the audio. By the time it's bad enough to break up the signal on transients you are hosed, before that is just poor sound quality.
When I began focusing on jitter as a potential problem, I ran through a series of experiments to see if I could make it worse first. It's easier to push on it and make it much worse than to fix it, and at least you've found the problem.
So, I started trying to overload the computer when sending audio, subtle at first, I put something else on the USB bus and send some data to it, or put nothing else on the USB bus and just ask the computer to do more work. The result was amazingly bad audio. Once you hear jitter (or ground loop noise for that matter) you can't un-hear it.
Switching to the optical out seemed to solve half or more of the problem. Ground loop gone, but also I wasn't penalized by having the USB bus tied up doing something else. Of course I'd rather fix the USB problem, but it's all a long running painful experiment.
For me the eye-opener was driving my headphones (LCD-XC) off the headphone monitor-out on my TASCAM DA-3000. It sounded twice as good as the Woo and Schiit, which of course is just a sign of a big problem, not some actual valid comparison. In the end it was jitter.
Hope maybe this helps you in some way.
