Dec 5, 2010 at 2:02 AM Post #16 of 35
It depends on your source...They sound pretty good unamped, but they won't be too loud with a portable player (55 ohms).. I don't think the Fiio E3 can power them well, you may need to get the E5 or E7
Dec 5, 2010 at 2:05 AM Post #17 of 35
I have an E5 coming in the mail next week so I think I'm gonna give these a try. Also, how is the K-240s bass compared to the HD 485s? The main thing I'm looking for is more bass than the 485s.
Dec 6, 2010 at 9:34 PM Post #18 of 35
I've also been looking at the Sennheiser HD 448s. Man, there are just way too many choices, every time I think I've found a headphone I can settle on I hear about 5 more that might be what I'm looking for.
Dec 6, 2010 at 10:09 PM Post #19 of 35
Sounds like you listen to a bit of heavier stuff (like myself.) In all honesty, I didn't really like the M50s for heavier rock and/or metal, but they're outstanding for hip-hop and rap.
Out of the 3 you've posted though I'd recommend going with the M50s.
Dec 7, 2010 at 8:48 PM Post #20 of 35
I'm open to other suggestions if you think they will better suit my needs.
Dec 7, 2010 at 8:50 PM Post #21 of 35
I've just heard too many good things about the m50s, and your selection of music seems perfect for them.
No way I can recommend anything else =p.
Dec 8, 2010 at 3:05 AM Post #24 of 35
Those Denons are looking like a good choice as well. My local Guitar Center carries the AKG K-240s and the M50s but they don't have any trial pairs, so if I wanted to try them I'd have to buy both sets. I also want to try the Beyer DT770s and the Denons but I can't find a place that carries them.
Dec 8, 2010 at 5:33 PM Post #25 of 35
Also, which phones have the better soundstage, the DT770s or M50s? I also found a pair of DT770s on ebay at $56 right now, do people usually try to steer clear of ebay?
Dec 8, 2010 at 7:13 PM Post #27 of 35
I heard that the bass isn't that great though. To make this as clear as possible, I want the headphone with more bass compared to the HD485 run through a Fiio E3 amp, and with so many options and phones I've been told about (M-50s, K-240, D1100, DT770, SRH440) I'd like the ones that have the most soundstage out of that group that have the amount of bass I'm looking for.
Dec 9, 2010 at 6:26 PM Post #29 of 35
Same soundstage as HD485=no soundstage
 what about Sony XB-700? I know many headfiers aren't gonna like this suggestion, but it could be a good idea if you want a lot of bass
Dec 9, 2010 at 10:52 PM Post #30 of 35
Ha, I know the 485s soundstage isn't that great but it's better than some cans in that price range, and I'm not a fan of the Sonys at all. I'm thinking the SRH750DJs or Beyer DT770s might be what I'm looking for.
