starcat
- Sep 15, 2008
How "big" is the difference between the SR-006II and the SR-007 both for the SRM-404 and O2 cans?
Originally Posted by starcat /img/forum/go_quote.gif How "big" is the difference between the SR-006II and the SR-007 both for the SRM-404 and O2 cans? |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif I will be reviewing the A-10 when it is released. I don't have any more information about when or features, other than what is posted at the RSA website. |
Originally Posted by vcoheda /img/forum/go_quote.gif ray is going to loan you one for review? i know you have an HE60. do you also have an O2. that's a must. |
Originally Posted by spritzer /img/forum/go_quote.gif The HE60 does like a lot of power but reviewing without a SR-007 just doesn't make any sense. |
Originally Posted by spritzer /img/forum/go_quote.gif He doesn't have an SR-007 so that's why he's asking me for a loaner. |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif I'm happy you haven't said NO yet, but would be relieved to find a loaner. I'm going to contact Asr and abs at nilenet.com, but would consider buying a used pair too. My problem is I'd have to sell an SRM-1 mk2 pro (or Travagans Green with SRD-6 or 7) with SR-5NB gold and a Darkvoice 336i dynamic amp with buttload of tubes to facilitate that. |
Originally Posted by spritzer /img/forum/go_quote.gif All electrostatic amps have to be dual differential (often dubbed balanced) or you would just get a heap of distortion but the input stage of the GES design is SE only. Same goes for the HEV90 and Aristaeus and you would need to make drastic changes to the circuit to make it fully dual differential. A XLR-RCA cable will only feed the amp with the + side of the balanced signal so it is just the same as using the RCA output of the source. You could add XLR sockets but that doesn't make the amp balanced either. It's a moot point though since there is no benefit from using balanced here and the quality of the source (and it's output stage) matters a lot more then what cable/connector you use. |
Originally Posted by HeadphoneAddict I'm happy you haven't said NO yet, but would be relieved to find a loaner. I'm going to contact Asr and abs at nilenet.com, but would consider buying a used pair too. My problem is I'd have to sell an SRM-1 mk2 pro (or Travagans Green with SRD-6 or 7) with SR-5NB gold and a Darkvoice 336i dynamic amp with buttload of tubes to facilitate that. Quote:
