hwc
- Sep 26, 2006
What do you think the HD600s and HD650s are made of? Plastic, plastic, plastic. The only pieces of metal are the metal cosmetic grilles (which the HD595s also have) and the metal headband, which is functionally not as good as the plastic headband based on complaints of excessive clamping pressure.
In many ways, the "build quality" of the HD595 is higher than the 600/650 series. For example, the cable attachment point to the driver is a miniature circuit board instead of somewhat unreliable springs. (I actually think this improvement was probably the result of automation in the Ireland factory).
Instead of a simple piece of cheap foam, the inner lining of the 595 is a nicely tooled little part with stretched acousic fabric. That simple little part would be hideously expensive to manufacture in Europe due to labor costs.
Plastic is plastic. There just happens to be an infrastructure of goods plastic molding factories in Southeast Asia, producing molded parts for everything under the sun -- from computers to TVs to iPods to headphones.
Originally Posted by Ikon I'm particularly disgusted by the HD595. The build quality is just cheap, cheap, cheap -> 100% plastic. |
