ahahahaha
Dude, good luck with this. We've all been down this path with him. He's just too stubborn, and won't admit that the tests don't jive with what he believes, so therefore it must be the tests fault.
Beeman reached his conclusion that blind tests are designed to fail before he knew about the blind tests that are passed for the likes of amps and codecs. So now he is stuck in a rut, unable to advance with the new information that does not support his initial argument.
I already know I'll fail. Why? Because the tests, for many past stated reasons, are flawed and are designed to assure fail. Maybe you've been fooled by the validity of audio DBT's, but I haven't.
Patrick wrote:
I hope beeman458 has a lot of disposable income...
That's very kind of you. And I hope you have a lot of disposable income also.
Patrick, you forget that auto-suggestion is a two-way street. Not only have I not been usurped by auto-suggestion, but it's clear that you have.
I'll be happy to let you prove that you haven't. Irrespective, you're more then welcome to keep the dream alive.
As to your continued efforts regarding my taking a DBT, there's no point as I've stated many times before, I already know I'll fail. Why? Because the tests, for many past stated reasons, are flawed and are designed to assure fail. Maybe you've been fooled by the validity of audio DBT's, but I haven't. I'm truly sorry that you've been lured by faulty reasoning but be happy, my money is safe as I have no need to buy any more cables as I have a boatload of them. The good news, quality cables, unless broken, never get old.
(I do need to buy a cheap set to get me over as I just received a new (used) DAC and need some RCA connects and my high end connects are at the retirement home.)
Cables are sickeningly expensive for no good reason... We sell a $400 cable at work and do you know what it costs me? $40 - $50 and I'm quite sure there's still good mark up there.
DBTs are designed to fail? how do they fix a DBT? neither the listener or the guy doing the test could, or it wouldnt be DB. now THAT is voodoo.
on that note, i would bet money that i could tell the diff between some stock cables and a moderately priced cable if i were to take place in a DBT.
but now we are on to arguting bigger, better things. like whether a DBT between a cable that costs a grand would yield results when stacked up against a cable that costs a couple hundred. in my opinion the result wold be that there would be no difference. If there is a difference, then it would be exactly that. the sound would be different. not necessarily better. the listener might actually like the sound of the cheaper cable better.
build quality, like was said already, does come in to play though.
Most folks don't have a clue what to listen for so it goes right past them, which is fine. It's not about "Golden Ears" as my ears are made of lead. What it's about is one's awareness of what they're listening for and whether these nuances matter to the listener; skill building. If these differences don't matter, no amount of coaching will aid them, just like any pursuit, it has to have an interest for you.I
If you did a little bit of research you would find a substantial number of positive DBTs,
I appreciate the thought, but I was writing about headphone cables as the title of the thread announces. In my comments, I'm not trying to address the whole spectrum surrounding DBT's although in the case of audio, my comments do go the full spectrum of the genre.
