preproman
- Mar 16, 2011
I'm not sure why the need to call out the GS-X MKII and Dynahi as being overpriced. First, the GS-X MKII is certainly a higher price amp that also work great with wider range of headphones from IEMs to higher to drive phones like Orthos. It isn't too bad of a value if you think of it, plus it also sounds superb as a preamp. The build quality is also second to none and it is very sought after in the used market which contribute to a good resale value. I also think it does one hell of a job driving the HD800. My point is there are higher price amps that perform even worst compared to the GS-X MKII but you didn't call them out.
Secondly, I do realize that KG did borrow some circuit layout from Nelson Pass, but the Dynahi circuitry is entirely done by KG and has been available to the DIY community even before the year 2000. My Dynahi with the gain dial down (20 to 8) is even better sounding than the GS-X MKII at driving the HD800. It also able drive lower impedance phones such as the CD3000 better than every thing else that I've tried. If you are good with DIY, the Dynahi can be build for less than 1.2k. Given that I paid for mine even less than I find it to be a great value.
We certainly can agree that Nelson's "kitchen table" is a superb choice for driving the HD800 but likely not suitable for easier to drive phones. Still one still need a pre-amp or DAC with attenuator build in to control in front of it to control the volume.
Hold on a sec.. I'm not calling any amp out in a bad way. The fact of the matter is, that compared to a First Watt amp the GS-X mkII is over priced and I would go that route any day of the week. I owned the GS-X mkII and loved it, but when the F1J came in I realized how much of a value it was compared to the GS-X mkII. You're correct in that it holds it's value in the used market - I sold mine for what I paid and saved a few $$$ in the purchase of the the F1J as it turned out.
The "Super Symmetry" was or is a Nelson Pas patent - That's what we was talking about right - "Super Symmetry"? Yes the D-hi came out before 2000. However, KG started to use the Nelson Pass patent "Super Symmetry" a few years ago. Look it up.
It's obvious you have a love for Gilmore / Birger amps. That's all well and good. However, there are better value and better performers out there. Same goes for the Nelson Pass amps.
Both KG / Birger and Nelson Pass has contributed lots to the DIY community - that goes without saying..
