GS-X MkII. Best I've heard with the HD800, and I own a WA5LE with great aftermarket tubes.
I absolutely love the GS-X Mk2 with the HD800s...but only if one's DAC is up to the task. The GS-X will let you know whether it is.
Some who have heard both would disagree
Dear magiccabage,
I agree with your judgement. GS-X 2 also sounds sterile and bright to me, very artificial sound with the HD800 (unmodded).
So far with solid state amp only the DIY Beta 22 fully differential and the new Japanese Luxman P-700u sound good with the HD800 based on my experience. I've heard Krell KSA-5 also sounds excellent but they are very rare.
Regards,
Jeremiah
Totally depends on your source. If your source is cold and sterile, then that's what you'll here, but then again the HD800s have been accused of being cold, bright and sterile too.With the Metrum Hex, the GS-X Mk2 / HD800s are as good as I've heard them. The Luxman was a bit syrupy and slow to my ears and if you're looking at changing the nature of the HD800s or your source, then maybe it's a good option.
Is there a tube amp any better for the HD800 than the WA2 for that same money.
Not including Glenns amps.....i know that they are
