When is the ifi iematch expected to be sold in Europe? Now only US
I have had one in the UK for almost a month now. Ordered it from Select Audio, not sure if they ship to the rest of Europe though.
That's what we call "to the point description" ! Many thanks!
Correct. If you already can't hear any hiss with your iems and current sources, the iEMatch won't make much difference unless you have a hard time getting to around 50% volume. Most sources/amps have their best dynamics at that range so if you have to keep volume really low to avoid being too loud the iEMatch might help there. Otherwise, unless you upgrade to another source that hisses with your iems, the iEMatch could make a nice future upgrade.
The iDSD Micro has a lot a tech that iFi is now beginning to export to other specialized products. It has the original usb iPurifier tech built-in but also the iEMatch and the Spdif iPurifier is based off of the iDSD's internals.
I had an iDSD Micro for about 2 years and since it has so many adjustments for gain and iematch I can't think of any reason why you'd need to use it and a separate iematch together. Probably would have a negative effect doubling the iEMatch tech.
need some clarification, please.
unsure if i need this item.
sensitivity ratings confuse me
(and i am googling this topic to better understand it...)
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=understanding%20sensitivity%20on%20earphones%20and%20headphones
currently I'm using the FLC 8S
[COLOR=000000]SPECIFICATIONS
[/color]
[COLOR=000000]Driver unit: 8.6 mm dynamic drivers+ dual balanced armature
[/color]
[COLOR=000000]Rated Impedance: 11 Ohm
[/color]
[COLOR=000000]Sensitivity: 93 dB/mW
[/color]
[COLOR=000000]Frequency response: 20Hz - 20KHz
[/color]
attached to dragonfly red or chord mojo then to ipod touch 6
...but i don't hear any hiss ...so i presume I'm ok.
also the micro iDSD already has this iematch (for home usage)...so i presume I'm ok there, too.
(just saw an earlier posting about 5 or so pages ago when a poster shows the micro iDSD and the iematch
iEMatch is definitely a perfect combo for LPG with sensitive IEMs.
Why would you use it over other choices? With Ety impedance adapter, you only have a choice of a single value resistance which might or might not work with your pair of IEMs (keep in mind, with some mulit-BAs you can mess up FR by adding impedance adapter). Then, you are only stuck with 3.5mm TRS SE connector, so if you have something like Hifiman or Plenue S or GeekOut DACs with balanced 3.5mm TRRS outputs - you can't use Ety. iEMatch gives you flexibility of 3.5mm TRS or 3.5mm balanced TRRS and a switch between two impedance settings to fine tune to your IEMs. On top of that, it has a very high quality aluminum connector housing and silver plated cable with nice strain relief. And, it cost the same $50.
With DUNU impedance adapters, again, you are stuck with a single value, and both sides of the connector are combined making it stick out. I prefer a split design of a 3.5mm male connector and female connector part where it becomes like a short extension to your headphones cable.
There is also a 3rd option, UE buffer jack which is quite cheap for $10, and has split design as well, but you are back to a single resistance value, no support for 3.5mm balanced, and just a basic rubber cable shielding and connectors. If you want to save money, UE buffer jack is the way to go. But if you want a lot more flexibility and higher quality, spend extra and get iEMatch.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Does this adapter reduce volume? I have a problem with FLC8s playing from SMSL M2 and Sony ZX1 - hiss. Unfortunately ZX1 isn't very powerful so I cannot afford loosing a lot of power. Is this a tool for me?
