Hiby has something like what you are seeking. It's called MSEB. I've used it and it's okay. It's slightly better than something like a Loki. I much prefer EQing to a target and then adjusting it to my taste.
Haven't tried the above app.
About the simplest system I can think of though (which I will often use in my own EQ projects for tweaking the overall sound of recordings or headphones, and also creating target response curves), would be a tilt adjustment to control the overall brightness/darkness of the recording. Probably in combination with some kind of a general midrange/Fletcher-Munson control, to adjust how forward or backward the midrange is relative to the bass and treble.
Having separate add'l adjustments for tweaking just the upper mids at around 2k, and maybe also the brightness in the low treble/sibilant range at around 8k or thereabouts could also be useful though, in addition to the two other types of controls above. And some ability to tweak both the center frequencies and bandwidths (or Q-factors) of the general Fletcher-Munson control, and maybe also the upper-mid and low-treble controls would probably also be useful in this type of setup.
As previously mentioned, a system of controls like this is relatively easy to set up or configure in Equalizer APO's Configuration Editor, using combinations of different graphic EQ and parametric EQ filters. The Equalizer APO Configuration Editor's interface is not particularly easy or intuitive to use though. Which is why I've tried to include some tips on it in the link in my signature. (Some others prefer to use the Peace add-on, which I have not used. And there are also some instructions on how to download and set this up on the official Equalizer APO webpage.)
Whether something like the above would actually work any better or more effectively or intuitively than the more traditional/old-school 3-band approach for bass, midrange and treble, I can't really say. It would probably take a bit of practice though to get the hang of this somewhat different and newer system though.
