johnjen
My only reservation with regards to spinning discs either digital or analog is mostly to do with the fuss factor AND especially in the case of digital, adding a DSP stack in between the spinner and the dac.
Because at this point with the results I'm able to achieve using carefully dialed in DSP tricks (PRT, HP compensation EQ, SSBB, and down sampling (where needed) etc.), results in a most compelling SQ presentation, that I wouldn't want to give up
And this degree of having the entire system dialed in is only possible when these tweaks are part of the package.
So when the very bottom end couples and is coherent and cohesive with everything above it, on a 'voice' by 'voice' basis, the results are quite sublime.
Of course the downside is that SuperDuperSuperGlue results in long listening nights
JJ
JJ
