- Nov 6, 2008
So how do I configure it? The above parameters can be adjusted; when one adjusts them there is a clear sweet spot, but there are tweener spots that sound worse than ass. Do I make it fixed? Do I make it adjustable? Do I make it auto adjustable? If it is fixed, I run a risk of overlooking a few recordings. If it is adjustable, users can adjust it very badly. In fact, when badly adjusted you could use it as a device to get rid of unwelcome company. Steady use could be useful to send bad roommates packing – I digress. If it auto-adjusts, this is where I run into the issue of computer power and memory – further the problem of how many samples the device needs to decide how to adjust or when to give up and light the BuyBetterMusic Laser. For the sake of proper music, that light should be so bright as to cause sunburn.
As far as to the paragraph above, this is what is in front of me. What I listen to as we speak are a Bach mass with my fixed MP. I am trying to listen to as many different types of music as possible as sample inputs; normally baroque is far from my fave – the MP helps that out quite a bit.
Welp, I can't see a better reason than for me to build a separate PC, water cooled Ryzen 1800x with dual 1080 Ti SLI, just for the Gadget! Wait, so are we calling it the MP or the Gadget now?
