nobody7284
- Jul 14, 2015
Which tips to recommend for Umpro30 ? Comply foam tips? Thanks
Wait till you switch to bigger size tips with tighter seal - the bass will hit you hard!!! Not a basshead muddy bass, but a well controlled slam with an authority! Welcome to UM Pro 50 club
I have them since tuesday and I am disapoint thinking that I will send them back, it so dark, very bassy, less energy, not clear as I would like.. via 5s and Clip. I do not know what is problem If seal or what, I tried them only with shure olive foam. I loved UM3X almost imediately a few years back and it sounded like I was there and accurate, clear etc. also do not feel this with um50. Sorry for negatives maybe it too soon for conclusions but maybe sombody can help.
Another info about UM PRO 50 after 10 days. Definitely prefer them with Sansa Clip, iPhone 5s is darker. I still think it is warmer on Clip as well and not accurate as I would like. It is strange because I think Westone know what they are doing so I do not believe it is bad maybe I have really seal problem (I am sure someone can find right seal even after a few weeks), truth is one day I really enjoyed them and felt it is great. But with UM3X in past I felt it was great every day I was connect with music and really felt instruments vocal.
So I will unfortunately return them..
I now understand what is a studio/stage monitor IEM. UM PRO 50's clarity is wayyyy better than the W30/50, Shure 846 that I owned. I cannot believe how clear I hear ALL the instruments with such separation. Wow!!!
you should listen to um3x!
UM Pro 30 is UM3X's replacement model? And if so, UM Pro 50 is a still a superior model compared to UM Pro 30, except for the slightly extra bass? either way, I am very satisfied with my UM Pro 50 and will not be inclined to listen to any other IEM for a long time to come. )
Yes, I will hear your um pro 50, maybe I'll buy them.
I wonder what is the difference?
[/quote
It may be almost the same except for the extra bass?!
I see you've decided to swap your UM Pro 50 for Shure SE846, and that you prefer the Shure SE846 bass ... I'm a little surprised.
I guess the Shure SE846 must be quite source dependent, as I thought the bass was inferior to the UM Pro 50. It does have a lot of sub-bass (rather too much IMHO) but I found the mid bass really lacking.
While I appreciated individual elements of the sound, the overall Shure SE846 sound just wasn't for me.
The only thing I preferred about the SE846 was the far sturdier build quality.
