not quite sure if i find it as distracting as u find it, but i concur.
i find the music quite veiled also
you might want to try this...this is my second go around with the W4's! the only reason why is because they where almost perfect for me the first time but lacked polish to the sound,
and on the W4 appreciation apprciation thread they talk about using a collar to allow the use of almost any normal tips with a lager diameter bore to them, this will allow th sound to open up and not be veiled!
well I did and they did, open up that is,
anyway I happily discovered the perfect collar to go over the W4 stem and allow ANY larger tip to be put on over it, they come from where I work, I work the paint line, and we use plugs to mask the threaded parts, and the smaller rubber plug fits GREAT over the w4 stem nice and snug with a nice large bore,
so if you want some, PM me and I can mail some out to you, no more canibalising other tips, not that that is a big deal for some of the ones that get torn up, but these plugs cold be a better solution in some cases,
anyway I am getting a deeper/better insertion with them, I started out as long as they would go and then trimmed them to what worked best,
here's some pics
^ the one on the left is the W stem section, on the right is the plug from work, bigger diameter
the plug from work on the W4 stem
![](https://www.head-fi.org/attachments/732702/)
another angle
so for anyone who wants to try experimenting with a couple of sets of them? hollar at me if you want the perfect adaptor, FREE of charge! I will put them in an envelope and send them on to you! I found it to be a great help with adapting any IEM to the W4! works as a collar/adapter, I get them free from work! the larger diameter bore, along with a regular IEM seems to NOT impeed the wonderful sound in the least coming from the W4, I am liking what I am hearing!
