I was just checking them out too but are they the new ones?
We are upgrading HE series headphones' replaceable earpads.
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- HIFIMAN Premier Sponsor Forum
I see HeadDirect has updated their site now with velour pads. I assume these are deeper than the stock HE-6 pads?
can you give a link please?
http://www.head-direct.com/Products/?act=detail&id=117
Thanks but I can't see from the image if this is the new type of mount. They look like the old, crappy ones that crack and make noises.
X2, they should update the description.
evilhippie
- Nov 7, 2011
just received a few sets of the new pads and I can confirm that they have the new mounting rings.
SanJoseCanJunkie
- Jan 25, 2007
If you have the leathers before the foam pads came with them, you can buy Creatology Foam Sheets from Michaels craft stores (they sell black), and cutting out two rings of foam for each earpad does the trick. It's only like $1 or so for the foam, but it does take a little finagling to get them in there and flattened out.
Apparently the new leather pads now comes a black form. I guess Fang does listen to his customers. Now the drivers is a little further away from the ears, and my outer ears is no longer touching the driver. Perfect!
nc8000
I've ended up with the leather pads from the FischerAudio FA-003. Ultimate comfort and paired with the HD650 headband inlay these heavy phoned almost disapear on head now
- Home
- Forums
