Hmmm - you talk about human hearing, but I don't actually talk about human hearing - I talk about perception. They are very different things. Hearing implies the abilities of the ear, and as you correctly state is very limited from psycho-acoustic testing, as the ear as a transducer is a poor device. Perception, on the other hand, is about the brain processing the information from the ears to create the audio illusion that we enjoy; perceiving individual sounds as discrete entities with each entity having it's own timbre, and placement location is a trick or illusion that the brain performs; it is not data from the ears, but a perceptual illusion created by the brain. Moreover, science has little understanding of how the brain performs this processing. And psycho-acoustic testing has nothing to say about the engineering requirements to perceive depth, instruments as separate entities, or individual instruments range of timbre; no research has been done on this at all. Psycho-acoustics actually is very simple, involving simple single tones - and we can't base our design requirements on such simple tests.
To give you an analogy; the ear performs like a 16 bit system - 96 dB dynamic range, 20 kHz bandwidth. Assume we have a system with peaks at +96 dB SPL and the ear can't resolve individual sine waves below 0dB SPL, and the traditional engineering view is that the system does not need to be concerned about signals below -96 dB (that's at 0dB SPL) as the ear can't perceive them anyway.
But put that signal thru an FFT, and now we can see signals buried in the noise; and with an infinite FFT window, we can see signals to infinitely small levels, if we wait an infinite amount of time... Now the brain does not do FFT's, but it is thought that correlation routines are used in perception - and correlation can be similarly used to expose signals well below noise. And I have had many instances where I can perceive the effect of errors even when those errors are too small to be audible directly. So if you had silence, with just the errors playing, it would be impossible to hear the errors; but mixed in with the music it is possible to perceive the effect of those errors; and the reason that they become audible is because they interfere with the brains correlation process that is used to perceive sound; and these correlation processes are working to a much greater accuracy than the ears performance.
And yes I do, as you say, "you suggesting extraordinary stuff in a perfectly casual way" because I don't care about the postings I make to whether people believe me or not. I do many listening tests, repeated on different occasions, and am confident in my outcomes. My listening tests are not about proving 100% that something exists to other people; they are about proving to me that something is audible and important - I am solely concerned about making better sound quality, and making progress towards truly transparent performance. Indeed, if my postings were about persuading people then I would not be so stupid as to post that stuff at -350 dB is important, as this is just plain absurd levels of accuracy. It's akin to homeopathy when dilution is down to one active molecule per litre, which would be absurd a claim to make that that level is important.
And before you say sighted listening tests, confirmation and expectation bias, placebo etc - yes sure these are very powerful things, and must be removed or taken into account when performing listening tests. And I do plenty of tests, where I can hear no nett change whatsoever (and get into trouble when posting about these results). And yes, when something extraordinary comes along I do perform single blind tests too.
Just to conclude with an anecdote; In the past I created and patented IP that was sold to large semiconductor companies; and my contracts with these companies meant I had to embed the IP into the corporations staff, so a lot of my role was education. And often I would get into big arguments with extremely clever and educated scientists, mathematicians and engineers; and these arguments would center on something being done a particular way for better sound quality. After several years of this, I felt like I was getting nowhere, so decided to show one of their engineers the difference in sound quality. So I invited him to my home and did some listening tests. One of the tests had a -180dB noise shaper, against a -200dB noise shaper. Both offered perfect performance from a measurement or hearing psycho-acoustic POV. The engineer was not an audiophile, and I conducted the tests single blind. He could readily hear the difference; afterwards he told me that what surprised him was not that he could hear the difference (as he trusted that I was not making this stuff up) but that how easy it was to hear these differences - it was a night and day change to him. He duly filed his report to the company, and thereafter I had no arguments as to whether something was important subjectively or not.
I think understand all your points, some I even agree with. others I really don't. but most of all, your anecdotes can't possibly be conclusive of anything to me because of how little I actually know of them. but I'm tempted to guess that the most likely explanations might not be the ones you decided to come up with. perhaps your beliefs on the subject make you less skeptical about potential errors in the test or more importantly,
the interpretation of it. but from where I stand, I couldn't satisfy myself with that sort of anecdote, given the world changing nature of the implications if all was correct. with noise shaping, I'd probably start wondering about the possible impact of the energy moved at higher freqs, and would want to measure the hell out of the analog output, and probably try other gears to check what role they might have to play in this.
but mainly I simply can't reconcile how ineffective the attempts to conclusively demonstrate the audibility of high res have been, with concepts where stuff at -200dB would be easily audible. that paradox alone kills the deal for me.
yes the brain does amazing stuff, and after all psycho acoustic is full of examples where altering just one variable can have a global impact on perception with often non intuitive relations, like how a FR change can impact impressions of dynamic, speed, position in space... so your ideas are very fair IMO, expect when it comes to the magnitudes you consider relevant. that just doesn't agree with any research I've seen.
I get the idea that a signal alone at -300dB might not have the same impact as that signal added to a clearly audible sound. from a concept of censor, there could be something too small for the minimum sensitivity of the censor to even react. but having it "carried" by a higher amplitude signal may or may not make the difference between 2 values for the resulting voltage or whatever quantization of it. I can't argue with the idea and possibility. but again I disagree with the magnitudes involved for the human ear. and I also disagree because acoustic masking directly contradicts your views on at least one aspect of sound variations at lower amplitudes. let alone the variation in signal, auditory masking "erases" the lowest magnitude information and makes it like it never existed in the first place for the listener so changing what isn't heard is not going to create much of an impression. and it's not just the brain deciding to pretend like he doesn't get the data, a concrete part of that lost signal has to do with the cochlea and purely mechanical and chemical reasons. even how the masking extends more toward higher frequencies, agrees with physics and how a loud low frequency signal is shaking everything in the area closer to the entrance responsible for capturing upper freqs. while high freqs dissipate rapidly so they have a hard time exiting the areas for lower frequency signals. it's pretty straightforward physic and suggest a loss of lower amplitude data because of higher amplitude signal.
there is also typical body noises, or simply cells firing up on their own as they apparently do, and ambient noise of course, making it impossible to just assume that everything will count and be taken into account by the brain as part of the music. all that exists as data, but is probably disregarded as noise and filtered out by the brain.
also there is complexity of the signal. a stimulus alone is more detectable than mixed in music(pretty much all hearing tests agree with that and give a JND much worst while the signal is within complex musical content instead of isolated. so practical situations also disagree with the idea of small changes in music being easily noticed. far from possibly letting us perceive stuff changing at -200dB, they won't even let us perceive stuff we could notice if they were heard alone.
in general just thinking about the necessary changes in the signal to give the perception of a different direction by even a tiny value like say 1°, or the variation in amplitude for us to notice a change from loudness(a little above 0.1dB under great conditions). first we realize that such variations while potentially noticeable on occasions, are not stuff that would really influence our experience of the music. who cares if the guitar is 1° more on the left? even trying to stay still, I'm surely going to move my head by more than 1° over the length of the track. those are anecdotal examples, but they both constitute unimportant changes while still being many magnitudes over anything going on at -200dB. yet stuff happening that low would somehow noticeably influence our impressions of the "room" in a relevant way? again my problem isn't with the ideas but with the magnitudes.
also as I've mentioned before, right or wrong, you have one luck, your vision aligns with trying to get higher objective fidelity. ^_^ which is never a bad idea. on the other hand, the guys who believe that massive aliasing in exchange of no ringing is improvement, they better have designed something that sounds subjectively nice, because objectively they really screwed up.
