astroid
- Jan 22, 2009
I dont want or need him to try to identify which is whicj , just see if he can consistantly identify a difference.
If he cant he cant , if he can well done.
For the record i tried and failed to consistantly identify one.
Originally Posted by haloxt /img/forum/go_quote.gif Well the problem is how do we know you didn't just make a duplicate of the same file. Or if you're just going to interpret olblueyez's findings to suit yourself? And the most olblueyez can do is say A sounds different from B, and if he says the cheap IC sounds better than the cambridge IC, it doesn't automatically mean there's no difference between cables or he's suffering from placebo, because nobody knows just how cable differences manifest. Then there's also the possibility that olblueyez DOES guess which one is the cambridge one, but then anti-cablers can rightly say he probably just guessed because there's only a 50/50 chance of being right if he guessed. The only real conclusion we can draw is that "IF there is a cable difference it can't be determined with this test". Do the unscientific test though, I'm interested in what heights we can reach with useless arguing. |
