Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
post-14943385
Post #3,496 of 3,580
Podster
Middle Earth
Middle Earth
Well, the F1 uses a pair of Single-Ended to Differential (Balanced) Line Driver chips (TI DRV134PA) to drive the 2.5mm TRRS Jack --- but the F2 appears to be using a set of 4x soldered-on JRC4580 op-amps for the Balanced circuit.
Quote from the AliExpress sales listing -
"... OPA2604 is responsible for voltage amplification, and four JRC4580s are responsible for current amplification. OPA2604 uses plug-in chip holders ..."
Far too technical for my feeble mind but for $35 I'm willing to hear the difference, I realize many can't go without a screen to pick and choose as they go but most the time I just hit shuffle all and let'er rip:grin: I mean if I've put the file on the player I like the music and just let my DAP's be my DJ's for the session:rolling_eyes: Looking forward to whatever sound my $35 has gotten me:wink:
Reactions: DBaldock9
post-14944184
Post #3,497 of 3,580
LaughMoreDaily
Canada
Canada
Thre is a new DAC/DAP/AMP from walnut with balanced output, the walnut F2, available on aliexpress for a bit more than $30. anyone ordered it already?
I look forward to the first reviews. That sounds like a steal!
post-14945424
Post #3,498 of 3,580
lujuris
Lima
Lima
Hello friends. I need help.
The NE5532 operational amplifier with which other is compatible?
I want to change the sound of my walkman.
I would like to receive your recommendations.
I have the DIY Walnut V2S
Thanks
post-14946916
Post #3,499 of 3,580
Themilkman46290
Earth
Earth
Thanks
I have 2xad825 in my v2s it's much better then the original
I ordered one on 06-MAY-19, and the Tracking info shows that it's already been handed over to the airline.
It should be here next week.
Let us know what you think of it, I am ready to grab one for the wife but curious how it sounds
post-14946964
Post #3,500 of 3,580
lujuris
Lima
Lima
Hello.
Sorry.
To put the 2xad825 you had to build a circuit or these are sold already manufactured.
Thanks
post-14946968
Post #3,501 of 3,580
Themilkman46290
Earth
Earth
Hello.
Sorry.
Thanks
They need an adapter
post-14946987
Post #3,503 of 3,580
Themilkman46290
Earth
Earth
post-14947022
Post #3,505 of 3,580
Themilkman46290
Earth
Earth
I am not sure, I can not tell by picture
Without the adapter they cost around 7 dollars each, that's $14 plus cost of adapter and from a good dealer it may cost a bit extra so I would expect it to cost about $20 or a bit more, check dealer feed back and when you buy from eBay remember if it seems to good of a price then it probably is a fake
post-14947292
Post #3,506 of 3,580
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
I found this. it's okay?
Here's a link to the BrownDog 020302 adapters that I buy (to install op-amps myself), and they also have an option to order it with a pair of AD825 op-amps installed, for US$19.50.
They will also install low profile, shoulder-less pins on the adapter, if you contact them and ask.
https://www.cimarrontechnology.com/browndog-020302-single-to-dual-op-amp-adapter
post-14948045
Post #3,507 of 3,580
LaughMoreDaily
Canada
Canada
post-14948184
Post #3,508 of 3,580
Themilkman46290
Earth
Earth
What's so special about the 825? I own an Audio Jade one but havent paid attention to it.
Someone asked for suggestions, it's one of my favorites in the v2s
Reactions: LaughMoreDaily
post-14963174
Post #3,509 of 3,580
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
My Walnut F2 arrived in the mail on Saturday.
The first thing I tried, was connecting it as an Amp, with a FiiO Taishan D03K (24-Bit / 192-KHz, Cirrus 4344) DAC for input, and with LZ A4 earphones (Green Nozzle, Red Back) connected to the Balanced Output.
Watching some BBC documentaries, streamed from Amazon Prime Video to my Roku 4, my initial impressions are that the F2 sounds good.
However, when I switched to listening to music, it was rather "thin" sounding - lots of Midrange & Treble, but not much Bass.
So, I opened the F2, and replaced the OPA2604AP with a pair of LME49710HA op-amps on a DIP-8 header.
Ah, there's the Bass. :ksc75smile:
I've also used the F2 as a USB Sound Card (it operates at 16-Bit / 48-KHz) for my PC, and as a DAP (playing WAV files of my CDs) - and it sounds good with the LME49710HA op-amps.
post-14963188
Post #3,510 of 3,580
LaughMoreDaily
Canada
Canada
I took out the 825 and put in the AD8066. It sounds better but there are more high peaks then the 825 with the KZ ZS7. I will try to burn in both opamps.
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
