Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
post-14662307
Post #3,481 of 3,580
LaughMoreDaily
Canada
Canada
If this thread has slowed/died down... I'm sorry to say Zishan stole the #1 budget DAP position from Walnut! Everyone is going Gah-gah over the Zishan DSD.
Reactions: D0rk!n
post-14662317
Post #3,482 of 3,580
Podster
Middle Earth
Middle Earth
Someone had to do it, it's the nature of this hobby:grin:
post-14662333
Post #3,484 of 3,580
Themilkman46290
Earth
Earth
I still use my Walnut but the dsd does get the most attention now
Reactions: LaughMoreDaily
post-14799829
Post #3,487 of 3,580
D0rk!n
Philippines
Philippines
try this to your walnut v2s.
1. Enable your phone bluetooth
2. then remove the mmc/sdcard of walnut v2s
3. then turn on walnut v2s
4. press and hold eq button for 3-5seconds then walnut v2s will be connected to your phones bluetooth so you can used it as external source of audio like spotify and deezer.
Credits to: https://www.facebook.com/euriteria213
post-14817579
Post #3,488 of 3,580
Themilkman46290
Earth
Earth
Hey guys, maybe you all can help me, i want to change the pot on my walnut (imbalance has become unbearable, full volume at 30%) i was thinking of getting an alps rk097 pot, has anyone ordered one? Can you send a link or the part number, so many variants that i am not sure witch one to order. Thanks in advance!!
post-14817699
Post #3,489 of 3,580
endia
istanbul
istanbul
i did change with this one but sourced from a local shop..
https://www.alps.com/prod/info/E/HTML/Potentiometer/RotaryPotentiometers/RK097/RK0971221Z05.html
also you might consider this too;
https://www.aliexpress.com/item/1pc...and-switch-shaft-length-17mm/32845207124.html
Reactions: Themilkman46290
post-14817788
Post #3,490 of 3,580
Themilkman46290
Earth
Earth
Reactions: endia
post-14943010
Post #3,491 of 3,580
noknok23
Netherlands
Netherlands
Thre is a new DAC/DAP/AMP from walnut with balanced output, the walnut F2, available on aliexpress for a bit more than $30. anyone ordered it already?
post-14943021
Post #3,492 of 3,580
MuZo2
Both links dont work, seems its not available yet.
post-14943022
Post #3,493 of 3,580
Podster
Middle Earth
Middle Earth
post-14943343
Post #3,494 of 3,580
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
I ordered one on 06-MAY-19, and the Tracking info shows that it's already been handed over to the airline.
It should be here next week.
post-14943362
Post #3,495 of 3,580
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
Not yet but I'm going to take the plunge just based on my V2/F1 stack, if you don't need a screen this thing should be awesome and once again a balanced output jack:thumbsup: Be sweet if they've gone and stuffed the F1 amp into this baby as the F1 will drive just about anything 600 and below:wink:
https://www.aliexpress.com/item/Walnut-F2-Professional-Lossless-HiFi-Music-MP3-Player-Max-Support-64GB-TF-Card-Expansion-USB-Sound/33012634762.html
Well, the F1 uses a pair of Single-Ended to Differential (Balanced) Line Driver chips (TI DRV134PA) to drive the 2.5mm TRRS Jack --- but the F2 appears to be using a set of 4x soldered-on JRC4580 op-amps for the Balanced circuit.
Quote from the AliExpress sales listing -
"... OPA2604 is responsible for voltage amplification, and four JRC4580s are responsible for current amplification. OPA2604 uses plug-in chip holders ..."
