Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
May 2, 2017 at 4:36 PM Post #2,857 of 3,631
But many have opened their walnut for op amp change didnt they see which dac its using I dont think it will be home grown for such a cheap diy dap.
the soc chip is actually scratched off manually so it remains unknown
May 2, 2017 at 5:10 PM Post #2,858 of 3,631
May 2, 2017 at 6:51 PM Post #2,859 of 3,631
There is an annoying ad in the way can you paste the specs? Much appreciated Mac.
May 2, 2017 at 8:31 PM Post #2,860 of 3,631
@T.R.A.N.C.E. posted a photo of a Walnut, before they started sanding the P/N off of decoder chip. The image appears to have been lost in the Forum software "upgrade".
It wasn't easy to read the text in the photo, but I believe U3 is in this family of chips - it's got the right number of pins...
https://www.alibaba.com/product-detail/MP3-decoder-ic-AC1082_60566717761.html
May 3, 2017 at 7:15 AM Post #2,862 of 3,631
May 4, 2017 at 7:53 AM Post #2,864 of 3,631
Well it seems the chip itself is why we don't have flac support. So much for a firmware update. :frowning2:
Not to change the subject, but for improved capabilities - take a look at the Zishan Z1, or wait for the next iteration of the Walnut.
May 4, 2017 at 8:00 AM Post #2,865 of 3,631
Using foobar2000, I've converted 252 of my albums of FLAC files, to 320Kb MP3 files (total of ~32GB).
Just to test and make sure they sounded OK, I listened to a few of them, using VLC on the PC, playing through my Micro iDSD, driving a couple of different earphones & earbuds.
As an experiment, I transferred 13 files (albums) to my new Walnut v2 (with socketed NE5532), hooked up a set of Qain25 earbuds, and started the music playing.
Wow, I'm impressed with the Bass!
Then, I switched to Qian39, and the Midrange (vocals), and overall balance, is also impressive.
