silverfishla
There was a period of time of about a month or so when the walnut factory switched to soldered SOIC8 opamp (OPA2604), but recently they have switched back to socketed DIP8 opamp due to feedback.
As has been mentioned there has been a few changes in the pcb, the extra usb port simply allows to load songs directly to the walnuts sd card, the new jacks are less secure and more prone to stress failure, but they are otherwise better quality jacks, gold plated with better contact prong design, the through hole rectifier diode has been removed and replaced with a smd voltage regulation. No significant changes really. I hear Nick says the pcb is wider, that''s good to hear, the old walnuts pcb wouldn't properly fit in the rails and would be lopsided in the case half the time.
I was wondering how you know all this stuff? I was wondering if there was a store that you know of for sure that has the absolute newest version of the Walnut, because if my Walnut that is coming in the mail is an older version, I would like to buy a newest one too. Is there a store that you know will ship the latest version?
