topping nx1 is a very neutral and extended (tonally) amplifier, and it is enough clean. but it only reaches 2Vrms (low distortion, at 64Ω).
http://www.head-fi.org/t/800208/the-rmaa-rightmark-audio-analyzer-source-and-audio-device-measurement-thread-measurements-in-post-3-tutorial-in-post-2/75#post_12994430
so it is very useful to boost low powerful DAPs (which deliver less than 1.5Vrms, like Sansas, Benjie S5, some AGPTek, etc. -0.5Vrms-) to feed hungry phones.
but it also can be used for other purposes.. for example, with the walnut V2. nx1 (2Vrms) doesn't boost the walnut (3.3Vrms at 64Ω, low distortion, in headphones out). but it does boost the line-out of the walnut (0.33Vrms), which have better response than its headphones out. you get less power than walnut's phones out, but also an output impedance of 0.1Ω (instead of walnut's 100Ω) and wider and flatter frequency response. so it can be better paired with low_impedance/high_sensitivity phones, which doesn't need more than 2Vrms power.
check the tonal differences in this graph; note the extra bass roll-off of gr07, due to the 47uF output caps, and the general highs roll-off of walnut's phones out. compare it to the walnut's line-out + nx1 frequency response, which is not altered by adding **** ues (lower impedance than gr07).
(anyway, i prefer to use a sansa or benjie with nx1 rather than using walnut this way..)
