IEMagnet01
Aka: IEMagnet, LeonardForbush, LanceP11, meekfella, BuddyGuy1, FredSavage, KillboyPowerhed, notthatguy.
- Nov 9, 2012
the VSD1 actually has bass presence and weight, while the Re0 has 0 bass and weight. The treble is better on the re0, and the re0 is more transparent and detail resolving. The VDS1 is more lively and fun.
Completely agree with this.
hriki - Are you asking which to choose between the VSD1 or VSD1S or is the GR07 in the equation as well? If so, no question I would go with the GR07. I haven't heard the VSD1S but from the description of others, it sounds like it would be a better fit for jazz than the VSD1. I also listen to a lot of jazz.
I am between these Vsd1 and Vsd1s but I am not sure if the clarity and instrument separation is good for jazz and electronic music. I try to find something in these money or a bit more (until 50-60€) with the characteristics of good bass, tremble and good separation of instruments.
Thanks for your help!
I'd try the TDK BA-200 for jazz at the budget you just posted.
I searched a little and it has very good reviews. If you compare them with Vsd1 you think that they have same bass and instrument separation or better? I am very close to buy them for listening jazz and electronic music. Even though I am not sure that the bass will be ok for electronic, I am sure that for jazz will be more than ok.
For electronic music, I would prefer a dynamic earphone for its weighty amd meaty presence instead of armatures like Ba200. Just my two cents![]()
I know and definetely agree with you. Ba200s have better bass quality and quantity than my Ultimate Ears Super Fi 5vi. But it can be a little weak on bass if someone is coming from a dynamic iem.
Yeah, that's why I love my Ortofon e-Q5s too![]()
I am coming from the native apple earpods. So I think that I will be easily impressed from many IEMS
Thanks for help!
