mochill
The vc1000 isn't pink they are red irl. ![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Sorry for the late reply. For me the W4 cannot put a foot wrong across most genres and same could be said to a point about the GR07. I would say the main difference between the 2 is that the W4 is more precise, detailed (like the SE535 but warmer). If I didn`t know any better the GR07 could well of been in the Westone family of iems. Better than the W2,(never heard the W3).
If the GR07 were in a different shell (I very much doubt anybody would disagree that build quality was extremely poor and cheap feeling) and priced at £300, I personally do not feel they would be in the other "over rated" thread.
I am a begginer to the IEM world. I am looking for my next IEM and I am sure you can help me.
I own a brainwavz m2 and a vsonic gr02 BE, with both I am pleased (with the m2 VERY pleased).
I enjoy listening to the m2 and I want an iem that is an upgrade to them. What I like with the m2 is that it has GREAT bass (with a good rumble) which adds to the overall full and fun presentation, the mids and vocals are good and the highs are calm and not too bright that matches my likings (IMO less harsh and sibilant than the gr02 BE), but the soundstage is not that big and the seperation could have been better (I am a beginer and I may be wrong with the terminology).
I mainly listen to vocal trance, a little bit of metal (iron maiden, rammstein, etc) and some vocal pop songs. The overall experience should be fun and exciting (not dry or analytical). I may not be a total basshead but the bass is important, in it's depth, quality and quantity.
My budget is ~140 USD. I searched the forums (reviews and multi-iem reviews) and found these iems interesting: gr07 BE (good reviews but a bit expensive), ATH-CKS77 (may be too bass centered), Dunu DN-19 Tai Chi (good but the gr07 BE are better).
I am short on budget, I bought the m2 for 45$ and the gr02 BE for 35$, so I take the selection of my next iem more seriously than before.
So... Do you think that the gr07 BE will match my tastes and I should get them or there is a different iem that will suit me better?
Thanks!
I can only attest for trance and pop songs. Can't say much for metal songs. These are perfect headphones for these genres. Believe or not there's definitely a burn in and no not mental. Everytime I put these on after some burn in I can say they just get better and better. Wish knew gr02 enough to tell you if these are an upgrade but if you are asking whether they are matching their price, I'd say look no further. I do believe they offer quality of higher end headphones. I'll not make demagogy by saying these beat this headphone or that headphone but they definitely play bigger than their size and price.
Buy them wayne DO IT!!!!!!![]()
Alright guys, today was gone with 24 hour additional burn-in (total 40 hours). I just put them on to check. I can tell bass tightened (not sure of the right word, but bass sounds less "shy-loose", much tighter and deeper. I believe they've hit a plateau by now. At the end I'd like to thank all who made my mind about these, waynes, sfwalcer, mochill, eke. Thanks to you guys I've discovered the premium headphones for my listening pleasure. Couldn't be any happier with my purchase. I hope they never break.
Tyll's got measurements:
http://www.innerfidelity.com/images/VSonicGR07BassEdition.pdf
They measure pretty much just like they sound; that is to say, quite well. Basically the same as the standard GR07, though boosted from about 500 Hz down. I'd still rather have the standard GR07, but the BE look quite good and still within the realm of being pretty neutral.
